Results 1 to 4 of 4
Thread: rotating Toto Vespin II toilet about 40 degrees
    DIY Junior Member electricboat's Avatar
    Feb 2012
    Toronto, ON, Canada
    Default rotating Toto Vespin II toilet about 40 degrees
    I have an existing Toto toilet which I am moving and replacing it with a Toto Vespin II.
    I would like to rotate the toilet up to 40 degrees to get it away from the side wall.
    I am wondering about drilling two new holes in the Unifit adapter so that I can rotate the toilet.
    Has anyone tried this?
    If the toilet flange has slots, you might get enough rotation by just sliding the bolts in their slots. If you're using the two fixed slots (generally stronger), that wouldn't work. You'd have to look at the construction of the adapter to see if it is reinforced well enough to put some new holes in it. There's not much stress on that connection if you follow normal practice and use some caulk to seal around the base after setting the toilet, so it would probably work. The wax won't care, it should seal regardless. The screws through the adapter into the floor are the primary means of anchoring of the toilet...the flange end only has to seal.
    Homeowner
    Jan 2010
    Alabama
    Default Unifit pictures
    Onetwo
    Feb 2012
    Toronto, ON, Canada
    I will take the existing toilet off to see the type of flange that is there.
    The thickness of the Unifit adapter is uniform. As seen in the pic from Hackney(thanks for posting the pics), there are ribs on either side of the existing holes for the washers to sit on.
    The new holes would move over to the 2 spaces between the ribs.
    The round raised portion on the bottom... 2nd pic from Hackney, is almost centered on the Unifit.
    I will make a template and see how it fits.
  1. Replies: 9
    Last Post: 12-01-2011, 08:09 PM
  2. TOTO VESPIN DOUBLE CYCLONE- 2 Piece toilet question
    By CPT in forum Toilet Forum discussions
    Last Post: 05-11-2011, 08:54 AM
  3. turing a toilet 90 degrees
    By junejulie19 in forum Toilet Forum discussions
    Last Post: 10-12-2007, 03:00 PM
  4. How important is a level toilet? (Toto Vespin intall)
    By sfphoenix75 in forum Toilet Forum discussions
    Last Post: 02-13-2007, 01:39 PM
  5. Turn a toilet 90-degrees
    By jadnashua in forum Toilet Forum discussions
    Last Post: 11-28-2006, 04:49 AM
