Page 4 of 4 FirstFirst 1234
Results 46 to 55 of 55
Thread: sparkling water??
  1. #46
    Quote Originally Posted by Marco_Guy View Post
    That is a clear glass, the water has the same turquoise tint.
    Then something may be casting a blue tint reflection on the glass because I see blue above the water in the glass, especially on the left side and front of the glass. Try a clear smooth sided glass.
    I've treated a lot of aggressive/corrosive water and have never seen anything like that before.
  2. #47
    DIY Junior Member Marco_Guy's Avatar
    May 2012
    FL
    it only happened as a result of the foamy/salty water.
  3. #48
    Nov 2010
    Maine
    That sort of copper corrosion can be a result of either high or low PH. In the North East we get a lot of low PH water conditions. I suspect the foamy/salty water may have dislodged that corrosion from inside your pipes which is why I asked if you know the PH of your water.
  4. #49
    May 2012
    FL
    i don't know the ph. maybe i can have it checked at my pool supply place...
    if it is copper pipe corrosion, wouldn't it have shown in the water when i put the water in the glass from the faucet? once the foam went away, the water appeared clear until i let it sit overnight.
  5. #50
    Nov 2010
    Maine
    Do you get any blue staining around the lav drains ?
  6. #51
    May 2012
    FL
    No blue staining.
  7. #52
    DIY Senior Member F6Hawk's Avatar
    Mar 2012
    Alaska
    Wait a minute... are you saying the sediment in that glass wasn't there when you poured it, but showed up in the glass the next day???
  8. #53
    May 2012
    FL
    Yes, after I let the glass sit overnight...
  9. #54
    Jan 2012
    California
    The bluish stuff in the glass, does it happen to be mushy? Or is it grainy?
  10. #55
    May 2012
    FL
    Unfortunately the wife tossed the sample last night. Hopefully it won't occur again....
