Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 55
Thread: sparkling water??
  1. #31
    Nov 2010
    Maine
    But he said in the original post that it was a Hague so................Nice try at covering up LOL
  2. #32
    I am not familiar withe the 23-BAQ, but newer Hagues, I believe by looking at the brine float, are under pressure. Troubleshooting guide indicates it, too. But I'll have to admit that I am not sure about the 23-BAQ model so won't make a claim to it.
  3. #33
    DIY Junior Member Marco_Guy's Avatar
    May 2012
    FL
    Default Still not fixed
    Replaced the brine valve and did a manual regen ~ 6 hrs ago and just watched foamy, salty "water" come pouring out of the kitchen faucet... no doubt the valve was stuck open, but apparently that wasn't causing the foamy/salty water...
    Any other ideas?
  4. #34
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    That would be exspected on the first regen. The salt tank had too much water because the brine valve did not shut off. Now the water should be lower so once the unit goes through another regen, the water should not be salty.
  5. #35
    May 2012
    FL
    Quote Originally Posted by mialynette2003 View Post
    Yep, no "standing" water in the salt tank any longer (it must have been broken for a long time because I always recall having standing water in that tank until today).
    Should I force another regen?
  6. #36
    No, just run off the water until it isn't salty or foamy.
  7. #37
    Yeah I know it is a Hague and not a Kinetico and I know the comment that softeners don't have a pressurized brine line unless they are in the refill position ("I believe") is incorrect because Kinetico is under pressure and now my good buddy Andy the Kinetico salesman is saying Hague has a pressurized brine line also. And you compounded the comment by saying there shouldn't be pressure on the brine line and had this Hague been newer, you would have been wrong.
  8. #38
    May 2012
    FL
    I did that.. I meant should I do a manual regen to ensure it doesn't happen again??
  9. #39
    Nov 2010
    Maine
    No, let the system run normal cycle. If you fixed the brine valve everything should be OK
  10. #40
    Quote Originally Posted by Marco_Guy View Post
    The No part of my reply was the answer to the question of should you do a manual regeneration; no, don't do that.
  11. #41
    May 2012
    FL
    OK. Not doing another manual regen. Hopefully the problem is resolved.
    Thanks for the help.
  12. #42
    May 2012
    FL
    Just noticed the "foamy/salty" water sample I saved from last night has a bunch of turquoise sediment in the bottom of the glass.....
  13. #43
    That's the color of corroded copper tubing. What does it look like in a clear glass instead of this blue?
  14. #44
    May 2012
    FL
    That is a clear glass, the water has the same turquoise tint.
  15. #45
    Nov 2010
    Maine
    It does look like copper corrosion. What is the PH of your water?
