Results 1 to 7 of 7
Thread: bronze fittings and copper fittings
    Default bronze fittings and copper fittings
    when will you use bronze fittings, such as cast bronze tee, when will you use copper tees in a copper pipe hot water heating system?
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Check my reply on the ridgid forum as i am not going to retype it all here !
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    By the magic of cut an paste, here is jerrymacs dissertation!
    For DIYfun, you may be confusing wrot copper or cast copper fittings, with brass , or bronze. No problem using ANY of those. Brass is more expensive, bronze fittings are not readily sold in this market and would be VERY expensive.
    Re: bronze fittings and copper fittings
    you have your terms mixed up, plumbers do not use bronze pipe fittings they use " brass " fittings
    if i am running a copper water system then i use all copper fittings
    but if you are talking about a hydronic heating system then i might use brass fittings
    the main difference between the two is cost as the brass cost more
    on the other hand if i was trying to finish a solder job and all i had was brass fittings then i would use them rather then taking time to go get copper fittings
    Aug 2007
    Thank you JIMBO
    for the assit should of thought of that myself
    MACPLUMB 777
    The cast bronze is the label I copied from Lowes.
    I found all the tees in my existing hot water heating system are "cast bronze". I noticed those "cast bronze" tees are more expensive. The copper tees are easier to solder and cheapier. So I was thinking there must be a reason for a plumber to use hard to handle and more expensive fittings.
    quote; So I was thinking there must be a reason for a plumber to use hard to handle and more expensive fittings.
    Not really. He may just have them handy, and some specific hydronic fittings only come in cast brass/bronze. Just because Lowes CALLS them cast bronze, does not necessarily mean that is what they are.
    Dec 2009
    northfork, california
    Typically, nowadays, you get a cast bronze or brass fitting that is a transition or has attachments that would cost more to fabricate onto a copper tube. Also, copper does not like to be threaded and machined.
    http://plumbing.hardwarestore.com/52...ap-251819.aspx
    And here is the bible telling you the metalllurgy and apps of cast fittings:
    http://www.copper.org/applications/p...ttgs_stds.html
  1. tightening copper fittings
    By tom gelzleichter in forum Plumbing Forum Discussion & Blog
    Last Post: 06-12-2009, 06:20 AM
  2. Sharkbite Fittings and old copper
    By AKRBT in forum Plumbing Forum Discussion & Blog
    Last Post: 09-06-2008, 02:25 PM
  3. Use of Pre-soldered copper fittings?
    By scatkins in forum Plumbing Forum Discussion & Blog
    Last Post: 11-27-2006, 03:41 PM
  4. pre-soldered copper fittings
    By Mattoest in forum Plumbing Forum Discussion & Blog
    Last Post: 08-26-2005, 08:31 PM
  5. Pre-soldered copper fittings
    By Plumb Crazy in forum Plumbing Forum Discussion & Blog
    Last Post: 07-26-2005, 12:29 PM
