Results 1 to 13 of 13
Thread: Dish Washer, is an air gap still a requirement?
    DIY Member tom12's Avatar
    Aug 2011
    California & UK
    Default Dish Washer, is an air gap still a requirement?
    I've noticed in another place a claim that there is now, in many states, no code requirement for using an air gap with a dish washer drain. The only requirement now is for a high-loop in the D/W drain pipe. Any comments?
    California uses the UPC code, which is one of the codes that requires the air gap fitting.
    The best thing would be to call your local inspection office and see what they want.
    We use the air gap in Washington State.
    Aug 2011
    California & UK
    Thank you Terry.
    Nov 2010
    Maine
    I live in Maine which is UPC and an air gap is required
    In NH (just over the boarder) which is IPC only a high loop is required.
    The safest connection is an air gap, whether required or not. It's up to you to decide, if you have the choice.
    Nov 2010
    Maine
    Modern dishwashers will usually have the high loop already installed on the appliance itself so running another under the sink cabinet effectively double traps the line which is not a good thing.
    Homeowner
    Jan 2010
    Alabama
    I installed my dishwasher with a high loop. I heard those sink top air gaps will fail and flood yo kitchen man. Thats a no go. Plus it looks like crap and takes up a hole in the sink. LOL
    I know they have a purpose but I'll take my chances. The last thing I'm worried about is the perfect storm happening and I get sick from how my dishwasher is hooked up.
    I worry more when I go out to dinner. I've worked in all those kitchens every plumber on this forum knows what I'm talkin bout.
    quote; running another under the sink cabinet effectively double traps the line which is not a good thing.
    It is a pumped discharge and therefore it can have as many "traps" as you want to use. Whether an air gap is required or not is usually a local issue.
    Nov 2010
    Maine
    It is indeed a pumped fixture but when you double trap it, water stays in the low part of the drain hose which is not a good thing if you can avoid it
    DIY Junior Member davianmcllm's Avatar
    Mar 2012
    Douglasville, GA
    First, I want to make sure I'm using the correct terminology.
    The little device that is connected to your dishwasher that sits inline with your faucet, etc. on top of your sink. Usually it has a little metal(or plastic covered with metal) cap on it and it let's air in.
    Second, I understand now that the CA code requires the something, but is there a way to do it differently so that you don't need that ugly little cap, etc. on your sink?
    If your local code requires one, you need one. Haven't really looked into styles of what's available. It doesn't have to be installed on the sink deck, it can be anywhere on the counter but that requires an additional hole.
    Plumber jimbo's Avatar
    But, THAT does open you up to the potential flood in the event of a backup. That is not something that should ever happen...but we know that things sometimes DO happen.
    And yet not all modern dishwashers have that. Sue's home had a new kitchen remodel, stainless appliances including dishwasher. She often had murky water in the dishwasher, sometimes enough to spill out the front when the door was opened. She had no "high loop" and no "air gap".
    The dishwasher was installed to the disposal, and the disposal had been plumbed without a p-trap. Wow! A complete kitchen remodel and they installed the new granite countertops with stainless undermounts without an air gap or a p-trap. Pretty gross!
    I went ahead and pulled the old antique disposer and installed a quiet Evolution disposer. Moved the drain in the wall and made sure that the disposer was now trapped before making it's way down the drain. The dishwasher now drains with an air gap on the counter top, and the bottom of the dishwasher is now clean, not murky. While I was at it, I added a frostfree faucet for watering outside to the piping under the sink.
    It's always better with an air gap!
  1. Using Dish Soap for Bugs
    By DonL in forum Lawn Care/Landscaping
    Last Post: 05-10-2011, 10:21 AM
  2. Proper Drain / vent setup for Dish Washer
    By jamiedolan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2009, 08:49 AM
  3. direcTV Sattelite dish mount
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 04-15-2008, 02:11 PM
  4. Installing new soap dish into existing ceramic tile
    By bbbluueyes in forum Remodel Forum & Blog
    Last Post: 01-09-2008, 05:08 AM
  5. Portable dish washer conversion
    By buildumup in forum Remodel Forum & Blog
    Last Post: 01-28-2006, 10:05 PM
