Results 1 to 13 of 13
Thread: Dish Washer, is an air gap still a requirement?
Hybrid View
    DIY Member tom12's Avatar
    Aug 2011
    California & UK
    Default Dish Washer, is an air gap still a requirement?
    I've noticed in another place a claim that there is now, in many states, no code requirement for using an air gap with a dish washer drain. The only requirement now is for a high-loop in the D/W drain pipe. Any comments?
    California uses the UPC code, which is one of the codes that requires the air gap fitting.
    The best thing would be to call your local inspection office and see what they want.
    We use the air gap in Washington State.
    Aug 2011
    California & UK
    Thank you Terry.
    Nov 2010
    Maine
    I live in Maine which is UPC and an air gap is required
    In NH (just over the boarder) which is IPC only a high loop is required.
    The safest connection is an air gap, whether required or not. It's up to you to decide, if you have the choice.
    Nov 2010
    Maine
    Modern dishwashers will usually have the high loop already installed on the appliance itself so running another under the sink cabinet effectively double traps the line which is not a good thing.
  1. Using Dish Soap for Bugs
    By DonL in forum Lawn Care/Landscaping
    Last Post: 05-10-2011, 10:21 AM
  2. Proper Drain / vent setup for Dish Washer
    By jamiedolan in forum Plumbing Forum Discussion & Blog
    Last Post: 03-09-2009, 08:49 AM
  3. direcTV Sattelite dish mount
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 04-15-2008, 02:11 PM
  4. Installing new soap dish into existing ceramic tile
    By bbbluueyes in forum Remodel Forum & Blog
    Last Post: 01-09-2008, 05:08 AM
  5. Portable dish washer conversion
    By buildumup in forum Remodel Forum & Blog
    Last Post: 01-28-2006, 10:05 PM
