Results 1 to 7 of 7
Thread: salt on water heater
    DIY Junior Member liam o k's Avatar
    Sep 2012
    indiana
    Default salt on water heater
    A friend asked me to look at her water heater that has a white mineral build-up on top. A plumber told her that it was because her chimney was inadequate and so the heater was not venting properly, so she called me. Using an incense stick while the water heater was running, I found that it drew the smoke very well. I found that a fitting was seeping (damn, i didn't check to see if was the hot or cold) and there was a layer of mineral on top that looked like the salt flats. I tasted it, and sure enough it was SALT. She does not have a water softener, and never has. She can offer no explanation as to why there should have been any salt in the vicinity of the water heater. It was installed in '94, is dripping at the drain, and purportedly pops and carries on while heating (though not while I was there) so it might as well be replaced, but what's up with the salt? PS Our local water supply is notoriously hard, but I've never heard of salt in the water.
    Plumber jimbo's Avatar
    The principal minerals of concern are magnesium chloride and calcium chloride. CaCl for sure tastes like salt. It is used as a salt subsitute.
    quote; I tasted it, and sure enough it was SALT
    It was her water heater so maybe you should have had her taste it. You were lucky it was not cyanide or something just as deadly.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by liam o k View Post
    She does not have a water softener...
    She should get one. The popping noise is due to all the mineral buildup inside the tank. Probably looks like the one in this thread.
    http://www.terrylove.com/forums/show...r-water-heater
    It is caused by rust/calcium nodules on the center flue which have small openings in them. The hot gases turn the water in the nodule to "superheated steam" which is then forced out of the small openings into the tank's water where it instantly condenses creating a "mini explosion" which is the popping sound. Over time as the openings get larger the water can circulate through them better so they no longer turn to steam and the sounds disappear.
    Sep 2012
    indiana
    So, what i'm getting out of all this is that there may be calcium chloride in the water. But, i've seen many leaky water heaters in this area with calcium (we always call it lime) build-up, and none have had that salt-flats type crusting that is so indicative of salt. Admittedly, i've never tasted a water heater before, since the deposits have never suggested salt to me before, but i have tasted the scale on my teapot: it's not salty. Could it be there's a peculiarity with her heater (the condition of the anode rod...) that causes an excess amount of calcium chloride to be produced? Or a peculiarity with her neighborhood's water supply?
    Mar 2011
    Houston, TX
    It could be rodent piss.
    I have never tasted it but I would guess that it taste salty.
    Normally the rodents will leave some turds also, That is not chocolate but may taste like it.
  1. Water Heater - will salt water damage the unit?
    By BARJRD in forum Water Heater Forum, Tanks
    Last Post: 11-20-2009, 05:12 AM
  2. Salt Build Up Around Water Softener?
    By statin in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-18-2009, 02:20 PM
  3. Water in the bottom of water softner salt tank.
    By JBoogie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2008, 10:38 AM
  4. Salt in well water
    By Mikebarone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2006, 09:46 PM
  5. salt in water due to softner
    By polocash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 08:25 AM
