Originally Posted by
dbestor
So, as an update, had Rheem send out one of their tech's for warranty service. They said the flame looked fine and refused to do any gas pressure tests.
Also, they did a drop test and said the temperature drop was right on "for a 29 gallon tank."
With that I got pretty upset given all of the "outperforms 50 gallon tank" claims in their promotional literature and press releases (one press release falsely stating that "Once the Rheem XR90 has been depleted of its available hot water, the unit can be ready with 90 gallons of available hot water in only 29 minutes.). I said the heater doesn't outperform my old 50 gallon (which gave me ~ 30 minutes of hot water in the shower). The tech put me on the phone with a Rheem rep, who stated that the XR90 will only match a standard 29 gallon tank for a continuous draw of hot water.
He claimed the tank only outperforms the 50 gallon tanks on recovery rates (e.g., after you stop pulling hot water out of the tank).
He concluded that a 15-20 minute shower using a 2.2-2.5 gpm shower head should be about all you get out of this tank. (then you have to wait another 30 minutes for the tank to heat up).
Now I'm stuck trying to decide whether to raise hell and get a lower efficiency tank, or stick this one out and crank up the temp on the tank...
But either way, Hackney Plumbing's calculations earlier in this thread of this tank supporting a 52 minute shower are way off, and should not be relied upon by those considering this tank in the future (assume 15 minutes).
