Thread: Softener/treatment system guidance
    DIY Junior Member llavey's Avatar
    Jan 2010
    Minnesota
    Default Softener/treatment system guidance
    Hello,
    I am requesting some guidance for a computer-less friend. If you need additional information to help me I'll do my best, here is what I know...
    He has a cabin in northern WI and is looking for information on what to do to prevent the rust stains that he is getting on his fixtures. the well is 1 year old. Water does not have any oder, Water usage is very low. Only one person and I don't think he is doing any laundry there yet. Any recomendations should be based on on low - medium use for two adults. His water tested as follows:
    pH 6.6
    Hardness 2.0
    Iron 1.4
    Nitrogen 1.0
    no softener, or filters of any kind are currently installed.
    Thanks for your ideas and recommendations.
    Link
    I would suggest a backwashed AN filter which would add 2-4 gpg of hardness to the 2 gpg and then a softener to remove the hardness and iron. The AN filter may remove some iron.
    By nitrogen I think you mean nitrate or nitrite. If it is nitrite that is serious and it should be removed because the EPA MCL is 1 ppm and 10 ppm for nitrate with the combination of the two not to exceed 10 ppm. At least that is what it used to be.
    He should have a Coliform bacteria test.
    Jan 2010
    Minnesota
    Gary,
    Thank you. I assume you are correct about the nitrate, I'll confirm his test results and do a little more research before continuing my request for assistance.
  1. New well Water treatment. Softener with tankless RO.
    By gdw_23 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-14-2011, 12:28 PM
  2. Looking for treatment system recommendations
    By Fishguy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2011, 09:31 AM
  3. need advice on water treatment system
    By bronzemaxell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-16-2010, 09:52 AM
  4. Iron treatment in Water Softener?
    By drraz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2008, 09:27 PM
  5. Water Treatment System
    By Truckman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2008, 06:51 PM
