http://www.google.com/products/catal...ed=0CD4Q8wIwAg
http://www.******.com/bosch-aquastar-1600h/stores-html
http://www.amazon.com/dp/B000KXWZ4G/...SIN=B000KXWZ4G
It's always better to install isolation ballvalves along with ports within the isolation for draining/deliming the thing, but unlike many bigger-deal tankless this one is a relatively straightforward DIY install. It's a low-end unit but they're easy to debug and adjust if it doesn't just fire up the first time.
Plan on cranking the hot-tap open pretty hard every time you start the flow to get it to fire up quickly (a quirk of the flow-powered ignition), but in cool-water MI you'd be able to back off the flow to more modest levels (just not a drip-drip trickle) and still have reasonable temperature regulation. In warm-water areas they can be pretty finicky at low flow and even flame out. If that should occur for you during the summer months the user-behavior solution is simple- get used to always maintaing a higher flow.
You wouldn't be able to shower and fill the tub simultaneously with this one the way you can with a bigger-deal tankless, but even with a tank filling a tub while someone is showering is an issue.
