Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Acid Neutralizer Questions
  1. #16
    As long as the static water level stays up you should be OK unless you start using more than 10 gpm. I would have suggested a higher gpm like 10-15 gpm and then whatever hp was need to pump from say 150'.
    That 5 gpm is called thr recovery rate of the well, your capacity or storage is the usable water in the well and a 6" well has (IIRC) 1.5 gal/ft from the pump inlet to the top of the water.
  2. #17
    Thanks for clearing up the terms.
    Once, I get the test results, I will return for treatment suggestions.
  3. #18
    Looks like I am okay. The total hardness is 43 mg/l, ph is 8.1 and total alkalinity of 54 mg/L. Totally different than my neighbors. My well ended up being deeper than theirs.
  4. #19
    Very good, thanks for the feed back.
  1. Acid neutralizer backflushing
    By jimmym in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2011, 07:40 AM
  2. acid neutralizer
    By devans175 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-19-2010, 08:05 AM
  3. Acid neutralizer question
    By Bob999 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-27-2010, 11:40 AM
  4. Acid Neutralizer Installation Questions
    By ACEschborn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-18-2009, 12:37 PM
  5. Acid neutralizer problems
    By 7072 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2008, 04:35 AM
