Results 1 to 8 of 8
Thread: clawfoot tub width and drain location
Hybrid View
    DIY Junior Member jodit123's Avatar
    Feb 2012
    Tacoma, WA
    Default clawfoot tub width and drain location
    I have a 54" clawfoot tub that I was planning to install in a bathroom that is undergoing a remodel. A few months ago, I had my house completely repiped and I had the plumber measure the tub and install a new drain (the bathroom was completely gutted at the time). I just moved along on the remodel just assuming all was okay. However, I just made the discovery that the drain is 28" from the wall and my tub is 30" wide.
    What are my options at this point? The floor is tiled and the walls are drywalled. I think there are 27" wide clawfoot tubs out there, but they are hard to find. Any ideas would be greatly appreciated, as I am a bit freaked out at the moment. Thanks!
    Aug 2009
    South*East
    Did you supply the plumber with a rough in sheet for the tub you were using? If not how was he to know were to rough in the waste?
    Looks like you both had a communication problem.
    John
    Feb 2012
    Tacoma, WA
    Smile
    Quote Originally Posted by johnjh2o1 View Post
    John
    The tub was on the back porch and he measured it before he set the drain location.
    Not sure what happened. I just need to figure out a path forward.
    How about a picture of the tub with the drain attached. IF the tub is 30" wide at the rim, the drain is probably NOT outside the tub, so 28" might be correct.
    A 30" wide clawfoot tub would be centered for the drain at 15"
    Is he planing on having the tub set out from the back wall 12"? That would be better then having the tub up against the back wall.
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by jodit123 View Post
    Dont get freaked out.....just move the drain ...or move the tub to match the existing rough in.
    Feb 2012
    Tacoma, WA
    Smile
    So sorry for the misleading description of the situation. Above I stated that the drain was 28" from the wall...it is actually 14" on center from the wall. Can you have a drain that is offset to accomodate a 30" wide clawfoot tub? Thanks again.
    Your original question implied that the drain was in the center of the long side, (which is not unusual for a leg tub), not the end of the tub. WHether you can offset the drain depends on WHICH drain you use and whether the offset would be visible, and thus objectionable.
  1. Clawfoot drain questions
    By keano016 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2011, 04:34 PM
  2. Slipper/Clawfoot tub drain
    By K2 in forum Shower & bathtub Forum & Blog
    Last Post: 01-02-2010, 12:23 PM
  3. Waste Drain assembly for Clawfoot Tub
    By Lina in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2008, 12:55 PM
  4. Clawfoot tub drain alignment
    By stamp in forum Plumbing Forum Discussion & Blog
    Last Post: 05-04-2008, 05:17 PM
  5. Clawfoot Tub Drain
    By rmelo99 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-07-2008, 06:10 AM
