Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: delta shower rough valve installation
    DIY Junior Member ratherbefishing's Avatar
    Nov 2011
    atlanta
    Default delta shower rough valve installation
    I hate to ask such a basic question, but....
    I'm about to install my new Delta R1000 rough valve. What size wood do you guys use for the stringer? By my arithmetic, it looks like it should be about 1.5 inches from the back of the studs. Shower framing is 2x4s, 1/2" permabase, Kerdi, 1/4" thick tiles. Does my math sound right?
    I know the second one of these I install will be a piece of cake. But this is the first.
    Thanx!
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by ratherbefishing View Post
    Thanx!
    The valve should have a rough in guide. Its black plastic and snaps onto the brass body. The finished wall should be flush with the guides front edge. I use a 2x4 or a 2x6.
    Remember to orientate the valve correctly...it has and up and down.
    Jun 2009
    Canada
    I guess you lost the instruction sheet already?
    Nov 2011
    atlanta
    I have the instructions. After I found some stonger glasses to read the tiny print, they still seemed kinda cryptic to a first timer. Online is easier; larger print! But harder to carry to the jobsite. Then I guess I had a late night brain fart. 1.5 inches from the back of the studs = 2x4. That makes sense, Delta. And it worked out even better. The "similar threads" at the bottom of the page answered my next question about soldering into the threaded inlet and outlet.
    Thanx!
    Feb 2011
    NW Ontario, Canada
    I'm about to install my new Delta R1000 rough valve...
    Does Delta make a 1000 series? I know they make a 10000 series cuz I have one. I know you can also download the instructions from the internet cuz I did just that. It spec's 70mm from the front of the plaster guard.
    Feb 2011
    NW Ontario, Canada
    Ja, but you can zoom it and print it.Name:  DSP-B-T17038_Rev_A_df49.jpg
    Homeowner
    Jan 2010
    Alabama
    Thanx!
    1.5" from the back of the studs doesn't mean anything. The valve should have came with a plastic rough in guide. You set the valve in the wall with the front edge of the black plastic guide so that it will be flush with the finished wall.
    Its really that simple.
    All of these valves have a min/max on the rough-in. If it is installed with the finished wall between min/max or the rough-in plaster guard device, the trim will fit BUT, if you are at one end or the other, you MAY NOT LIKE IT! So, temporarily, put it together with the trim to see how much of the shaft/handle you want sticking out, then measure, and mount the valve there. There are LOTS of people here that have posted complaining about how it looks (not how it functions) because they didn't mock it up first. To the manufactuer, if it fits, it's right. To the consumer, they usually, don't like it at either extreme. The engineer's version of min/max may not meet the fashion design sense of the user. CHECK IT FIRST!
    quote; It spec's 70mm from the front of the plaster guard.
    We do not use metric in the USA. But if we did 7 cm would be easier to read on the ruler. When installing any recessed valve, you measure from the "face" of the finished wall back, because that is the only "positive" measurement you have.
    DIY Junior Member patma's Avatar
    Jan 2013
    Kentucky
    W/ delta, better to be too deep or too shallow (if you gonna mess up). I've installed extension kits when valve too deep or tile changed at last minute but have never had to correct one too shallow. I guess the only solution would be to reset the whole body?
    Delta give you 1/16 or so to play w/ on the normal trim kits? tia
    DIY Junior Member loudgonzo's Avatar
    Jan 2014
    Wylie, Tx
    I'm installing the R10000, and after mocking it up, the handle sticks out too far, so we would need to install it about a 1/4" -3/8" deeper into the wall. However now the problem is that using a 2x4 as the stringer, the stringer won't be flush between the studs, it would also need to be pushed further back.
    Is there any problem using a thinner hardwood as the stringer, allowing it to remain flush with the studs. I was thinking something like 1x3 oak, which is still rigid/hard enough to mount the valve too.
    thanks,
    1 x 3 PINE would be adequate. You are not going to be hitting it with a sledge hammer. In fact, once the trim plate is attached and tightened up, the backing may be incidental anyway.
    Jul 2009
    North Vancouver, BC
    Default Backing for plumbing fixtures - 3/4" plywood
    post(s) deleted by John Whipple
    Jan 2014
    Wylie, Tx
    Since the depth will be greater by about 1/4" outside the max specified depth, does this affect the operation? What happens if the valve is too deep?
    Jul 2009
    North Vancouver, BC
  1. Replies: 6
    Last Post: 06-07-2011, 01:26 PM
  2. Kohler Bancroft Bathtub Drain and Delta Bath/Shower Rough in Valve
    By GinnyQueen in forum Shower & bathtub Forum & Blog
    Last Post: 04-20-2011, 10:30 PM
  3. Rough Plumbing for Delta multiple shower heads in Tub/Shower?
    By jsarin1 in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2010, 08:22 AM
  4. Delta shower valve rough-in
    By northman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-15-2008, 11:40 AM
  5. Delta MultiChoice Rough In Valve
    By Mike2007 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2007, 01:20 PM
