Thread: New Carrier Natural Gas Furnace - Noisy during ignition
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default New Carrier Natural Gas Furnace - Noisy during ignition
    Since I intend to sell my home when the market rebounds (hope I live long enough), I purchased a new Carrier natural gas furnace. I chose the least expensive as I am hoping to leave as soon as I can. Problem is it is noisy as heck, especially during ignition. The vibration is very pronounced and takes 30 seconds to ignite during the rumbling. I called the installing contractor and he basically said you got the cheapest Carrier and it makes noise. Any thoughts. He is coming out next week just to be sure the fan (housing) is not loose and said he is not replacing it even if it is defectively noisy.
    Is this a closed combustion device? If not, normally, the only fan is the circulating fan. If they didn't use a noise isolating fitting between the furnace and the ductwork (it's in all of the installation instructions I've looked at, albeit not that many!), then it will transmit any of that vibration to the ductwork that can act like an amplifier.
    DIY Senior Member Rich B's Avatar
    Sep 2008
    New Jersey
    A natural gas furnace will have a draft inducer motor that runs before the unit fires. If you hear noise duing the starting sequence, I would look at that little motor first. Maybe something is loose or the motor/fan combination is noisey. Could just be a loose screw or pice of sheet metal making noise.
    The blower fan would not come on untill the unit fires and the control board has been signaled that it has fired. The draft inducer stops running after that as it's not needed.
  1. Need help with Carrier Furnace and LP connection
    By dcorazal in forum HVAC Heating & Cooling
    Last Post: 09-15-2011, 11:29 AM
  2. Carrier 95% Natural Gas Forced Air Furnace
    By sarrowsm in forum HVAC Heating & Cooling
    Last Post: 04-02-2011, 01:54 PM
  3. furnace-no ignition
    By pitteach in forum HVAC Heating & Cooling
    Last Post: 12-22-2009, 03:26 PM
  4. Furnace - Slight Delayed Ignition
    By Jeff_08 in forum HVAC Heating & Cooling
    Last Post: 04-28-2008, 05:24 PM
  5. Williamson Natural Gas Furnace Problem
    By Ted1 in forum HVAC Heating & Cooling
    Last Post: 10-11-2007, 07:02 PM
