Results 1 to 3 of 3
Thread: Can the Triangle Tube Boilers Be Programmed?
    DIY Junior Member Ferretman's Avatar
    Feb 2012
    Colorado
    Default Can the Triangle Tube Boilers Be Programmed?
    I have a Triangle Tube Solo 175 boiler.
    There's a nice big network interface of some kind (looks like a proprietary serial bus) on the front under the panel, but I don't see anything at all about how to program this puppy. I'd like to be able to limit when it runs so it doesn't kick off at a particular time of day.
    Is there a network interface/control of some kind for this thing? Can it be programmed?
    Steve
    In the trades Dana's Avatar
    Jan 2009
    It's not an internet attached device, nor does it run Windows 7 (thankfully! :-) ) but yes, they're "programmable" , and it needs to be programmed to optimize in-system performance.
    Have you consultedthe manual?
    Programmable thermostats (or timers) in series with the thermostats on the zones would be able to provide the time of day function you are seeking. It's better to let the boiler controls control the boiler, and use more appropriate devices as the timers.
    A connector style does not a network make, but the series is designed to be able to run multiple boilers in parallel, which requires a connection to a central modulation control unit.
    Feb 2012
    Colorado
    Quote Originally Posted by Dana View Post
    Thanks for the pointer to that manual....I didn't have it.
    As you note though that's not quite what I mean. You can do a lot of stuff through that (lousy) menu interface but not quite the level of programming I'm looking for. I guess I could replace the various radiant heat controllers with something more programmable, but of course what I was hoping to do was shut off the boiler at certain times.
    Anybody know what one can do with this interface? I would assume it's really for some kind of diagnostic device and doesn't really support what I'm after either though, does it?
    Ferretman
  1. Replies: 47
    Last Post: Yesterday, 04:19 AM
  2. Replies: 0
    Last Post: 01-15-2012, 05:51 AM
  3. Triangle Tube Prestige Excellence Boiler Use
    By Offsite in forum Boiler Forum
    Last Post: 12-18-2011, 08:23 AM
  4. Solo110 with smart40 indirect hot water heater triangle tube
    By Brian Morgan in forum Water Heater Forum, Tanks
    Last Post: 04-24-2009, 09:33 AM
  5. Programmed versus manual activation
    By baronoff in forum Irrigation / Sprinkler Forum
    Last Post: 07-23-2008, 07:39 AM
