Results 1 to 7 of 7
Thread: Bacteria Issues - New Well
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Bacteria Issues - New Well
    Just had a new well drilled for my cottage located in Northern Michigan. Was on a shared well previously. Used the continuous variable speed power pump and am happy with that. However, after several unsuccessful water sample tests, we are getting a no pass on the bacteria content of the water. The reputable well digger said he will "bomb" the well shaft with chlorine, then retest. The water is off to the cottage having been blown out before the cold winter. I am concerned that "even if it passes as a result of the chlorine, would that not just be a false negative, so when the chlorine is flushed out the bacteria could return?" How should I handle this. The well was dug some 89 feet, the 50' adjacent septic systems isolation distances were honored as I pulled a permit, and the other cottages along the beach with wells dug at this level have had no problems. Thanks.
    Jan 2008
    "Bacteria" is a general term that doesn't mean much.
    Fecal coli-form now would be telling us something.
    If the well water is contaminated, then the piping is also. The entire system must be treated with chlorine.
    If the driller contaminated the well, a proper and complete chlorine treatment should fix it.
    If the water table is contaminated from another source, the problem will be likely to return.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Most bad tests are a false positive.
    It's easy to get a bad test, it's hard to get a good one.
    Dec 2009
    northfork, california
    If he is not recirculating the water down the well head, its all for nothing.
    DIY Junior Member Mikei16's Avatar
    Feb 2012
    Dutchess County
    Default If he is not recirculating the water
    If he is not recirculating the water down the well head, its all for nothing. ? What is the benefit of recirculating the water down the well head ?? I am re-using an older well that has not been used for sometime.
    Mike
    Jan 2008
    The bacteria is/can be living on the wet walls of the bore hole and the casing. The chlorine solution should be recirculated to coat all surfaces inside the well. After the contact time has expired, the re-circulation should continue while the well is being pumped off to clean the well.
    Dec 2009
    Not to mention the bacteria that came in with the new equipment. And maybe a few dog turds.
  1. Well Bacteria fix
    By 4me2see in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-14-2011, 07:48 PM
  2. Softener and bacteria?
    By mar3232 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-05-2011, 11:29 AM
  3. Orange bacteria
    By pudge565 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-13-2011, 09:26 AM
  4. Iron Bacteria
    By liveinfixer in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-13-2011, 09:13 AM
  5. Bacteria or sewer smell
    By bauz in forum Shower & bathtub Forum & Blog
    Last Post: 04-30-2005, 04:13 AM
