Results 1 to 2 of 2
Thread: Honeywell AM-1 Thermostatic Mixing Valves. ( water heater tempering )
    Default Honeywell AM-1 Thermostatic Mixing Valves. ( water heater tempering )
    Honeywell AM-1 Series Thermostatic Mixing Valves. ( water heater tempering )
    Many plumbing codes require a tempering valve to prevent scalding if you have a tub that people bath in. A tempering valve takes the cold water and mixes it with hot water and dials it down to a suitable temperature.
    Some adjust between 70 F and 120 F
    And you can also get one that does 70 F to 145 F
    Raising the water in the tank to 140 F helps to prevent the growth of Legionella bacteria.
    • Allows homeowners to store water at 140 F and
    higher to prevent legionella growth, but receive
    safe, comfortable 120 F water at sinks, shower
    or tub
    • Designed to increase the amount of usable hot
    water by up to 50 percent
    Installing the AM-1
  1. Honeywell AM101C-1 vs Apollo MVB-34 Tempering Valves
    By Terry in forum Water Heater Forum, Tanks
    Last Post: 03-27-2013, 11:50 AM
  2. Mixing Valve for Tempering water
    By handyman923 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-02-2013, 03:50 PM
  3. Tempering Valves for residential water heaters.
    By tom12 in forum Water Heater Forum, Tanks
    Last Post: 12-04-2012, 11:14 AM
  4. Replies: 1
    Last Post: 08-16-2011, 01:34 PM
  5. Use a Thermostatic Mixing Valve in a Solar Hot Water heat dissipator
    By Herman Hartzler in forum Solar and Geothermal Water Heating Forum
    Last Post: 07-28-2010, 08:07 PM
