Thread: Drain Spout
    DIY Junior Member Antigone's Avatar
    Feb 2012
    Damascus, MD
    Default Drain Spout
    I just finished tiling my bathroom shower/tub. Unfortunately, I just realized that I made the hole a little wider than my drain spout. So, when I screw the spout on there are places that the tile does not even reach the spout. Since I cut the hole a little too much, I am not able to put a piece of tile to cover the "spaces/holes" up. I really want to avoid caulking, so if anyone else has another idea that would be very helpful.
    Thanks....
    You may be able to use an plate or escutcheon behind the spout.
    While it's a pain, if you have some extra tile(s), you can remove the grout around the bad one(s), then break the tile, and then install new one(s) so that it will cover the hole. As an alternative, you may be able to find a tub spout that has a larger footprint, or try to find an eschution plate you can live with.
  1. Stuck Tub Spout & Drain Flange
    By katharine in forum Shower & bathtub Forum & Blog
    Last Post: 10-20-2011, 01:06 PM
  2. "Standard" tub / drain / spout
    By DavidTu in forum Plumbing Forum Discussion & Blog
    Last Post: 04-21-2011, 07:59 AM
  3. Tub Spout won't come off
    By 007 in forum Shower & bathtub Forum & Blog
    Last Post: 01-30-2008, 06:06 PM
  4. Tub spout
    By Illtryonce in forum Shower & bathtub Forum & Blog
    Last Post: 11-23-2005, 07:54 PM
  5. Removing tub spout and drain
    By Lloyd in forum Shower & bathtub Forum & Blog
    Last Post: 03-09-2005, 05:11 AM
