Results 1 to 3 of 3
Thread: Tankless water heater cold water line
Hybrid View
    DIY Junior Member prbearden's Avatar
    Feb 2012
    rockport, tx
    Default Tankless water heater cold water line
    Greetings,
    When installing a whole house tankless water heater (electric, if it matters) do I need to take the cold water input directly off the meter or can I connect to any cold water pipe in the house?
    Jan 2009
    YYou can pretty much take the cold feed from anywhere, but you'll get less pressure drop/higher flow if you run it direct to the meter with 3/4" line. But that may not be the limiting factor to hot water performance, particularly with an electric tankless, since high flow rates are out of the question due to the comparatively low heat-input capacity of an electric HW heater.
    Feb 2012
    rockport, tx
    Thanks, Dana!
  1. Tankless hot water shutting off when more cold water is needed
    By Dwight Marshall in forum Tankless Water Heater Forum
    Last Post: 10-04-2011, 01:36 PM
  2. Water Going Cold with Takagi Tankless
    By monty in forum Tankless Water Heater Forum
    Last Post: 05-28-2010, 11:09 AM
  3. Water heater question - cold water, water leaking thru overflow pipe
    By jonyi in forum Plumbing Forum Discussion & Blog
    Last Post: 09-26-2009, 01:26 PM
  4. tankless turns on when I turn on the cold water
    By dswang77 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-28-2008, 03:23 PM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum Discussion & Blog
    Last Post: 10-12-2004, 06:20 AM
