Results 1 to 5 of 5
Thread: washer plumbing
    DIY Junior Member dugulater's Avatar
    Jan 2012
    Georgia
    Default washer plumbing
    i am installing a washer and dryer and have a few questions. The easy one is the typical height of the drain box (top of open pipe). My second issue is more frustrating for me. I have two drain lines to connect to. One is a cast pipe but it is 3 feet off the ground. The other option is a pvc pipe that goes out the side wall at ground level... only issue is it is 1 1/2' inch not 2 ". The thought of tapping into a pipe so high scares me and i can't figure out how i pull off a trap. The 1 1/2" pipe was used by the previous owner and is a dedicated line to the septic tank buat all i read says it is too small. Btw, there is no venting issue with either... i will tie into a 3" pipe going directly to the roof. Thanks for opinions on the best of two evils.
    Plumber jimbo's Avatar
    UPC calls for the washing machine trap to be between 6" and 18" above floor, and top of stand pipe to be 18" to 30" above trap. That makes the top of the standpipe between 24 and 48" The 3' ht of your pipe is a problem. Exactly what is that smaller pipe? What is connected to it now?
    Default drain
    Au contraire! You do have a venting problem because that 3" pipe is a "drain" NOT a vent.
    Jan 2012
    Georgia
    Default clarification
    The 1.5" pvc pipe was installed by previous owner as a dedicated line for the washing maching. So, it is connected to nothing in the house. It would be the ideal option but i am worried about it backing up because of the smaller diameter. I can replace the 1.5" with 2" up until the point it goes out the wall. The good news is that it is at the floor level.
    Jan 2012
    Georgia
    HJ - I don't think i have a venting issue because the 3" pipe is dry except for a bathroom sink. The toilet and show all flow into the pipe below the connection for the washer. basically, each drain has a dry pipe attached above any water flow.
  1. Need help with plumbing for washer, NSPC
    By alwaysfine in forum NSPC Plumbing Code Questions
    Last Post: 07-12-2012, 09:41 AM
  2. washer plumbing problems
    By planner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-10-2011, 04:53 PM
  3. Need help with plumbing for washer, NSPC
    By alwaysfine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-09-2010, 08:52 AM
  4. Help with Washer Plumbing
    By rmelo99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2008, 08:28 PM
  5. New plumbing for basement washer
    By Al S in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2007, 07:17 AM
