Results 1 to 10 of 10
Thread: Water heater gas control magnet assembly
    Homeowner
    Jan 2010
    Alabama
    Default Water heater gas control magnet assembly
    This video shows a gas water heaters magnet assembly. The thermocouple is screwed into the bottom of the magnet assembly. I removed the magnet assembly from the water heater control valve to demonstrate why you must hold the "red button" down while lighting the pilot.
    In the video the top of the magnet assembly that I push down with my finger would have a steel rod direcly connecting it to the "red button" you depress to allow gas flow through the control valve to the pilot assembly.
    The pilot light heats the thermoscouple to generate millivolts of electricity that charges an electromagnet. Until the thermocouple has been heated enough to charge the magnet you must hold the "red button" down to allow gas flow.
    In the video I use a torch to heat the thermocouple and then depress the plunger and the magnet is charged. It holds the spring allowing gas to flow through the valve to the pilot.
    When I turn the torch off,that would simulate the pilot being blown out or otherwise not present as to prevent the burner from firing if the thermostat called for flame.
    When the electromagnet is no longer being charged the magnet can no longer keep the spring contracted.
    http://www.youtube.com/watch?v=HNMIs89J-dM
    Feb 2005
    now that was 2 minutes of my life that I will never forget
    you got way too much time on your hands
    god created all men,
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by master plumber mark View Post
    I know how you feel but 5 times worse. I watched the 11 minute video pasted in the bottom of your posts. Thats what you get when you do too much LSD as a youngster as I believe the guy in the video has.
    Feb 2005
    actually he is a professor in quantum mechanics
    and string theory...up in canada
    so you were lost you after the first 10 seconds??
    Homeowner
    Jan 2010
    Alabama
    No not lost I just dont believe what other people dream up and claim to have figured out the universe...... then apply it with a calculator.
    Feb 2005
    Quote Originally Posted by Hackney plumbing View Post
    well, dont worry about it....
    just keep working on that gas control valve magnet.
    that video is gonna go viral someday.
    Homeowner
    Jan 2010
    Alabama
    Whats to work on? I was doing a demo of what happens when your holding the red button down. I hope you learned somthing while watching it,if not maybe another guy did.
    if you need me to explain anything about the video just ask and i will try to help if I can.
    Feb 2005
    no, I am good....
    the internal workings of a gas thermostat has never been
    a burning question on my mind....
    here is some more weirdness for you
    http://www.youtube.com/watch?v=lBNv8...ure=plpp_video
    Homeowner
    Jan 2010
    Alabama
    Thats what I thought. Alot of people have never considered what happens when your holding the red button down after lighting the pilot.
    Feb 2005
    Cool
    well different strokes for different folks......
    it takes all kinds to make up this quantum universe
  1. Canted Control Valve on new GE water heater from HD...Buy it or not?
    By ST1300Rider in forum Water Heater Forum, Tanks
    Last Post: 01-25-2012, 04:36 AM
  2. How do I remove the brine piston assembly at the control head of a Fleck 2510?
    By Biddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-01-2011, 09:22 PM
  3. Gas Hot Water Heater-Temperature control
    By jkcsanchez in forum Water Heater Forum, Tanks
    Last Post: 08-22-2009, 11:30 AM
  4. Whirlpool water heater gas control valve replacement
    By casablanca in forum Plumbing Forum Discussion & Blog
    Last Post: 02-25-2007, 07:12 PM
  5. Water Heater Temp Control problem
    By Chuckg7 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-08-2006, 07:08 PM
