Thread: adding shower to 1/2 bath - questions around drains
    DIY Junior Member bigballer's Avatar
    Aug 2006
    Seattle, WA
    Default adding shower to 1/2 bath - questions around drains
    i want to add a shower to our 1/2 bath and need to figure out the drain design. the drain would tie into the main exit between the washing machine (ahead of the shower) and the toilet (after the shower). there is another bathroom and kitchen ahead of this as well. sooo how do i keep the shower drain from becoming a geyser? is it just a matter of installing a Y correctly? this is all on the main floor of the house and all in a line along the back wall of the house - like so: bathroom (tub/toilet/sink) -> kitchen sink > washing machine > bathroom (toilet/sink). i am not above having a PRO do this for me but if something a realtive novice can accomplish, i will do it.
    thanks
    To cut in a drain, you would install a wye fitting, and then a wye fitting for the vent. You will need a vent after the shower p-trap and then you can wye it into a waste line.
    The vent goes through the roof.
    ALL plumbing is a "matter of installing the fittings properly". Between installing the proper "Y" the proper way, and installing a proper vent, it is probably NOT a diy project.
    Aug 2006
    Seattle, WA
    how does this look for design?
  1. old house adding drains looks ok?
    By petros151 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2011, 02:23 PM
  2. Adding new bath - need help with DWV please
    By Boogerhead in forum Remodel Forum & Blog
    Last Post: 02-26-2009, 07:19 PM
  3. adding shower to half bath using washing machine plumbling
    By rhoxsie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2008, 06:43 AM
  4. Adding Shower to half bath in basement
    By cicerored in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2008, 03:21 PM
  5. Adding a shower to a 1/2 bath
    By EMJ65 in forum Remodel Forum & Blog
    Last Post: 10-23-2007, 02:57 PM
