Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Kohler canister flush valve drops too quickly
  1. #16
    Apr 2012
    New York, NY
    Quote Originally Posted by jd944 View Post
    I'll be changing both of my toilets over to the old fashioned flapper flush valves. Do they use more water, maybe. Do they require more maintenance? Probably. Do they flat out work? Definitely.
    Good luck with that. The Kohler canister flush uses a unique size hole in the porcelain, and so isn't easily replaced with an aftermarket flush valve. If you had an American Standard toilet with a tower flush or funnel flush, or a Toto or any number of other brands with a 3" flush valve, you could swap it for the Korky Large 3" Adjustable Flush Valve Kit, model number 5030BP. www.korky.com That kit uses a nice Korky 3" flapper and a twist-to-adjust-the-height flush valve and overflow riser. But that item clearly states that it does not fit ANY Kohler toilets...
  2. #17
    DIY Junior Member jd944's Avatar
    Dec 2013
    Palm Harbor, Florida
    Smile
    Quote Originally Posted by wjcandee View Post
    I'm very much aware of the unique design of these units. If they can't be retrofit, I'll replace the toilets. I bought them to save water and now they're wasting water. Before I give up I'll check with a few large suppliers like Sexauer or Grainger. Like I said before, when they were new, they flushed perfectly with one flip of the lever. Not so three years later. I'm sorry but I can't subscribe to the opinion that they are working like they are supposed to. I'm not trying to be argumentative but I believe in calling it as I see it. There are a lot of people complaining about the same issue on these toilets. I find it hard to believe they're all guilty of operator error.
  3. #18
    Apr 2012
    New York, NY
    I will just make my usual comment to the effect that if you want a workhorse toilet that does the job every time but is not outrageously expensive, check out the Toto Drake (it's the original model of Drake) CST744S (1.6gpf) or CST744E (1.28gpf). It should be available for about $200+ ish, not including a seat. Great toilet. Have two of them. Flushes very well. Decent if not exceptional bowl rinse. Well made. Uses standard, easily-replaceable parts, most of which are made in the USA by Korky and for which there are Korky replacement parts. There is also a CST744EN, which has a different (N for "new") tank which looks more traditional and less-modern.
    The Toto Drake II, CST454CEFG, is an upgrade, with better bowl rinse, a Sanagloss stain-resistant finish, and Universal Height all standard. But we love our original Drakes, and think they are a best buy.
  4. #19
    DIY Junior Member TM8's Avatar
    Apr 2014
    NY
    I know this post is old...but I wanted to reply with how I solved this problem in case it can help anyone else. After having the Fluidmaster valve replaced, I had the same problem. The canister would fall too fast and not enough water would go into the bowl to flush it. A plumber couldn't even figure out how to fix it and said I'd just have to hold the handle down for several seconds each time. Well with several young children in my house, they were never going to be able to get it to flush each time. I finally realized the Fluidmaster float needed to go up much higher to keep the water level higher in the tank. This keeps the canister "flapper" thing buoyant long enough for the proper amount of water to get into the bowl and flush it. I did have to remove the fine adjustment rod on the side of the Fluidmaster unit in order to be able to turn the unit 360 while pulling up to get it to rise (the adjustment rod would hit the back of the tank keeping me from turning the unit). It only went up an inch at first...which wasn't high enough to keep the canister buoyant long enough. After messing with it longer and pulling harder, it went up to the top of the tank. The water now fills to the very top of the canister (when it's seated all the way down), and this is high enough to keep it from dropping down too fast. I hope this helps someone who is as frustrated as I was!!!!
  5. #20
    Apr 2012
    New York, NY
    Of course, cranking up the water level to a point higher than it used to be is going to destroy part of the water-saving nature of the toilet.
  1. Kohler toilet canister valve not staying up
    By jdevo in forum Toilet Forum discussions
    Last Post: 04-05-2014, 07:33 PM
  2. Kohler Wellworth Canister Flush Valve chain tangling?
    By glacial_erratic in forum Toilet Forum discussions
    Last Post: 11-13-2010, 03:35 PM
  3. How to remove Kohler Rosario/Rialto flush valve?
    By wc9 in forum Toilet Forum discussions
    Last Post: 05-17-2009, 01:35 PM
  4. Kohler 3402-PB Rialto OLD Flush Valve
    By Lindakota in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-22-2008, 12:42 PM
  5. Replace flush valve on old Kohler 3402PB?
    By markyyy in forum Toilet Forum discussions
    Last Post: 03-12-2008, 01:08 AM
