Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Clear solder from brass fitting
    DIY Junior Member cmose's Avatar
    Mar 2007
    Indiana
    Default Clear solder from brass fitting
    I was soldering a one inch brass fitting to one inch copper. Couldn't get the solder to take on one side of the fitting so I took the fitting off before the solder set. Now the fitting has a good bit of solder in it - can I clean out the solder to reuse the fitting (if so how)? Had to special order this fitting be I'd prefer not to wait on another one if I can avoid it.
    Jun 2009
    Canada
    You took it off before the solder set...?
    What torch are you using?
    Mar 2007
    Indiana
    Benzomatic mapp torch
    DIY Senior Member JerryR's Avatar
    Jul 2011
    Florida
    I am not a pro but this is what i would do..
    Heat it up until solder melts, grab it with vice grip and slam it on a piece of wood to drive out as much hot solder as possible. When it is cooled off use a 1" stainless brush to clean out remaining solder. You may be able to use sandpaper to clean it out after it is cooled.
    If you are using a propane torch I suggest you get a MAPP gas torch instead. It burns much hotter.
    Jerry
    JR
    Mar 2007
    Indiana
    It's benzomatic's yellow cylinder, not sure if it's true mapp.
    It isn't because they stopped making "true" MAPP in January 2011 after a fire in the plant. The new stuff is MAPP+ and burns about 400 degrees less. Heat the fitting and use a cloth to wipe the fluid solder out of the socket. If you use a brush it will solidify the solder as soon as you insert it so you will not get all of it out. When it is hot, slamming it on a piece of wood could dent it.
    Mar 2007
    Indiana
    I thought I remembered reason something like that but wasn't certain.
    I've tried heating the fitting a few times - gotten the thing read hot, but there are still a few ridges of solder inside the fitting. Does the fitting have to be devoid of solder and perfectly smooth to reuse? Or can it contain some solder and ridges so long as the pipe fits?
    Jan 2008
    If the pipe fits without binding it should be fine. Any solder that is in there will melt and distribute when you sweat the fitting.
    Mar 2007
    Indiana
    Thanks for all the advice. Tried yet another time but had the same dead spot that wouldn't take solder as before. Tossing this fitting and ordering another one!
    Jan 2008
    Sounds like your fitting or pipe is not clean.
    If your joint is properly fluxed and there are no tight spots, the solder will pull from one side all the way around the joint.
    Mar 2007
    Indiana
    Don't think that was it. Spent 15 minutes ensuring the two sides were pristine the first time (knew I didn't have extra). Was liberal and thorough with the flux as well. Both times it was the same spot that wouldn't hold solder.
    Plumber jimbo's Avatar
    You mentioned that in the attempt to clean, you got it "red hot". Overheating brass and copper can sometimes affect the metal in a way that subsequent soldering is very difficult. That said, I can not explain why there is one spot on your fitting that won't take. Anyone seen this before???
    Jun 2009
    Canada
    Well if he insists on this "red hot" heating method, that I've never heard of, I can't imagine how that would work well.
    Homeowner
    Jan 2010
    Alabama
    He probgably overheated the fitting/pipe and burnt his flux up before the solder ever hit the joint.
    Jun 2009
    Canada
    Ding ding ding.
  1. Can I solder a copper to brass threaded connection?
    By Scott Vroom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2011, 10:50 AM
  2. Compression or Solder Fitting
    By GoldMaple in forum Shower & bathtub Forum & Blog
    Last Post: 09-06-2009, 09:02 AM
  3. Solder Copper to Brass?
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2009, 05:38 PM
  4. can you solder copper and brass
    By Don Juan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2005, 06:54 PM
  5. ABS Compression fitting to Brass tub drain
    By DIYMike in forum Shower & bathtub Forum & Blog
    Last Post: 03-06-2005, 05:48 AM
