Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Hot water coming through cold water line
  1. #16
    Dec 2009
    northfork, california
    DIY Junior Member mrdojo's Avatar
    Jan 2012
    Utah
    Well, I finally got this all resolved so I thought I'd come back and report. First off for Hackney plumbing: I never did try exactly what you had mentioned so I can't say what the result of that was. To ballvalve: regarding your comment: "When you open a hot tap, the cold water cannot flow in the opposite direction. I dont care where your bag in a can is located." You're right, and this was my "fix" for getting cold water more quickly - turn on a hot water tap at another location, then turn on the cold where I was getting a drink. Since the hot water can't flow both ways that seemed to do the trick.
    But more to the point, this morning the original plumber finally came back and took off the expansion tank from the hot side and put a new smaller one on the cold side. This seems to have fixed it as was expected. Yea!! He said he had never seen that happen, but was nice enough about it. I just wish he wouldn't have been so hard to track down and get out to fix it. But, all's well that ends well I suppose.
  3. #18
    All of the installation instructions for an expansion tank call for it to be on the cold side...the ones designed for potable water are NOT designed for use on hot, plus, some of the other issues you noted. On the cold side, any that might discharge would be cold, not creating any problems, and being cold, the bladder should last a much longer time as it was designed for.
    They do make expansion tanks for boilers that go on the hot side (obviously!), but they are specifically NOT designed for potable water.
    But, when setup properly, you rarely should get much more than a cup or so of water pushed into the expansion tank during a reheat situation. It sounds like the static pressure in the tank was low for your local water pressure, allowing much more hot water into the tank, making the problem worse, and stressing the expansion tank as well.
  1. Water Coming out of Shower head Cold But just right at tub before pulling diverter
    By Thefreightman in forum Plumbing Forum Discussion & Blog
    Last Post: 11-28-2011, 10:59 AM
  2. No cold water coming from my single handle Pfister lavatory faucet
    By anglii in forum Plumbing Forum Discussion & Blog
    Last Post: 06-08-2011, 09:45 AM
  3. Bladder to feed a cold water line that has low flow on city water.
    By FBXFixIt in forum Plumbing Forum Discussion & Blog
    Last Post: 09-17-2009, 09:58 AM
  4. Hot Water Coming from Cold Water Supply
    By slomo in forum Plumbing Forum Discussion & Blog
    Last Post: 12-13-2008, 07:04 AM
  5. Very little cold water coming out of shower.
    By Sorcha in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2008, 10:27 AM
