Results 1 to 6 of 6
Thread: Where to find Magnesium Anodes for 50 Gal Gas GE/Rheem? Model PG50T9A....Thanks!
    DIY Junior Member ST1300Rider's Avatar
    Jan 2012
    South Carolina
    Default Where to find Magnesium Anodes for 50 Gal Gas GE/Rheem? Model PG50T9A....Thanks!
    I've checked all over the net and can't find a 42" Magnesium Anode for a 12 yr old GE Profile (Rheem) 50 Gallon Gas WH.
    I am looking for a 42" that will fit GE/Rheem 50 Gallon Gas Tall built in 2000....
    Can anyone point me to a website.
    All I have seen are some "Reliance" brands that fit AO Smith.
    Jan 2012
    South Carolina
    Hackney....
    Thanks man!
    As usual...you always come through with the info!
    Hope I can break the 12 yr old anode loose!
    Jan 2012
    South Carolina
    Hackney...
    Ifound this one for 1/3 the cost and it is a Rheem magnesium 44" from the same company for 20 bucks.....
    http://fierychill.com/magnesium-anod...rheem-sp11524c
    What's the diff except 403 dollars?
    Jan 2012
    South Carolina
    Or this one?
    http://fierychill.com/rheem-ap11345c...long-magnesium
    2 inch longer and 40 dollars less?
    Some wh the anode is hung on the inlet pipe...some, it is screwed into the tank. That may be the difference or one could be bigger in diameter than the other. Easiest thing is to call them and ask...hopefully, they know their inventory.
    Also, unless you have VERY tall ceilings, you probably need a segmented rod or you'd have to uninstall the tank to put one in while it was on its side.
  1. Choosing model series from Rheem and Bradford White
    By HDClown in forum Water Heater Forum, Tanks
    Last Post: 01-15-2010, 06:54 PM
  2. RIP 21 y.o. Rheem. What's next?
    By pmoe in forum Water Heater Forum, Tanks
    Last Post: 09-16-2009, 01:33 PM
  3. Anode rod - magnesium - right choice ?
    By dikshe in forum Water Heater Forum, Tanks
    Last Post: 02-17-2009, 06:14 AM
  4. Where to get water heater anodes?
    By mortimer in forum Plumbing Forum Discussion & Blog
    Last Post: 07-28-2008, 08:11 PM
  5. where can i find the model # on my toto toilet?
    By bakchoi in forum Toilet Forum discussions
    Last Post: 10-25-2007, 05:10 AM
