Results 1 to 7 of 7
Thread: Baseboard electric heater & switch distance from whirlpool bathtub?
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Baseboard electric heater & switch distance from whirlpool bathtub?
    Completely remodelling a small northern michigan cottage bathroom. Installing a whirlpool tub in a small 5' x 9' bathroom with only one outside wall with only 3' of available space for an electric baseboard heater. Wish to install an electric baseboard heater between the tub and the bathroom sink. How far away does code require that is be from the tub, i.e. both the baseboard 220v heater and the whirlpool switch to energize the tub motor. Thanks.
    Jun 2007
    North Carolina
    Outside the footprint of the tub
    Aug 2009
    South*East
    If you can reach it with one foot in the tub it's to close.
    John
    Unless this is a DIY tub that you are converting yourself you should not need a "switch" on the wall. The tub should have an on/off air switch mounted on it so that the tub just plugs into an energized GFCI outlet, or an outlet downstream from a GFCI outlet which is usually more convenient. The heater is a sealed circuit, so you can put it anywhere it fits.
    Jan 2011
    levering, michigan
    Thanks for the reply Rock! The whirlpool tub motor will be connected to a GFCI, but wonder still beyond code concerns if a bather would touch the energized elctric baseboard heaters from inside the water filled tub, if there was any kind of short in the heater wouldn't there be an electrocution danger? The heaters will be 22v, and cannot be put on a GFCI themselves. What do you think?
    Jun 2007
    North Carolina
    I think that if it is properly installed there is no more danger sitting in the tub and sticking your finger into the heater than sitting on your recliner and switching channels on your tv with a remote except the heater might be a little warmer than the remote
    Jun 2007
    NY State, USA
    Quote Originally Posted by johnjh2o1 View Post
    John
    I just KNEW someone would be along with the incorrect answer after JW's correct one.
  1. Hi, more electric baseboard heater questions.
    By Danimale in forum HVAC Heating & Cooling
    Last Post: 11-30-2009, 12:13 PM
  2. electric baseboard question
    By garageland in forum HVAC Heating & Cooling
    Last Post: 11-16-2008, 06:00 PM
  3. electric baseboard or hydronic baseboard
    By hids2000 in forum HVAC Heating & Cooling
    Last Post: 01-17-2008, 06:02 AM
  4. electric baseboard heater
    Last Post: 07-15-2007, 07:34 PM
  5. Electric Hot Water Heater used for Baseboard heat
    By enosez in forum Plumbing Forum Discussion & Blog
    Last Post: 01-30-2007, 03:02 AM
