Results 1 to 13 of 13
Thread: Waterworks, Sigma, Can't identify faulty shower mixing valve?
    DIY Junior Member johnsas's Avatar
    Jan 2012
    ny
    Default Waterworks, Sigma, Can't identify faulty shower mixing valve?
    Name:  ageneral jan 2012 003.jpg
    My shower valve is faulty (can not increase water temp) but the only marking on it are;
    TX1 REN 04708??
    Any help appreciated!!
    I think that says 04/08, which could be a manufacturing date. The only thing your picture tells us is that it has a square shank using a rotary motion, and "maybe" has a thread to hold that brass plate on. We need a picture of what is under the brass plate, and maybe also the piece inside the valve.
    Homeowner
    Jan 2010
    Alabama
    Its a Watts Industries Uk Ultramix.
    Plumber jimbo's Avatar
    Holy check-valve, batman! How did you know that?? Here is the dope>
    http://www.wattsindustries.com/image...tx83_86_gb.pdf
    Homeowner
    Jan 2010
    Alabama
    I had a computer program built that I load the photo of the faucet and it spits out what type it is. problem is alot of manufactures "borrow" parts from each other so I may get several hits of possibles.
    are you selling that software? you could make a bundle!
    Homeowner
    Jan 2010
    Alabama
    LOL I was just "messin with the MoD"
    I googled it. I just typed in tx1 shower faucet and scanned through the results until I found one that applied to what we are doing here.
    Wouldn't it be nice to have a program like that tho? It would be great. I have alot of old faucet books,etc etc
    Supply houses usually will give their old books to you.....just ask befo they throw them away.
    Jan 2012
    ny
    Hey thanks all!!!
    I did try to get the front plate off but as it would not come away easily i did not try to force it.
    Does this type have a replaceable cartridge??
    Thanks Hackney Plumbing! interesting name for one based in Fl? And a winged Pegasus by any chance?
    red winged Pegasus equals Socony Mobil
    That is a European valve. Good luck getting parts. It was probably installed by a builder and chosen by a foo-foo designer who had no regards for future issues. The building contractor may know who the distributor is....check with them.
    Jan 2012
    ny
    Builder has long since ridden into the sunset!!!!
    Am I right in thinking that the front plate should come off?? (ie to remove the cartridge)
    Jan 2012
    ny
    Name:  a shower valve 002.jpg
    thanks all!
    Job done!!
    My existing and new one ordered.
    For future reference, this valve is used by Water Works # 29-99396-53953 or Sigma 18.30.147 You can buy here in the USA. http://www.chicagofaucetshoppe.com/S...29-99396-53953 I hope this helps someone.
  1. Shower mixing valve
    By tommy h in forum Shower & bathtub Forum & Blog
    Last Post: 01-12-2013, 07:28 AM
  2. Help - Identify Old Amer. Stand. Mixing Valve
    By fineline in forum Shower & bathtub Forum & Blog
    Last Post: 06-13-2010, 03:36 PM
  3. Need new shower/tub mixing valve
    By Scuba_Dave in forum Shower & bathtub Forum & Blog
    Last Post: 10-26-2009, 11:17 AM
  4. Mystery Mixing Valve---can anyone identify? Nibco
    By Flutie7NFL in forum Shower & bathtub Forum & Blog
    Last Post: 09-24-2008, 03:21 PM
  5. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
