DonL
If the ground was connected properly then you should not get shocked even if the AC polarity was reversed.
Did you get it wired correctly ?
It may have been just capacitance building up voltage on the fridge's frame without any real conductance, or, on the other hand, a leakage current from the circuits in the fridge and enough to give a good tingle or more; still, can't be too safe without a gound to drain it away or trip a breaker if it was a real short to the frame from the hot.If the ground was connected properly then you should not get shocked even if the AC polarity was reversed.
Kleenex ®The electrician rewired the outlet. There is no ground wire and the wire is two insulated wires wrapped in a rubber/plastic type coating.
Thats a harbor fright $1.99 tester, but they actually work, though not likely safely. I regret to admit I have several spread about in odd places where one need not hunt for the 'real' one.
Can't afford to buy new batteries for that price.
A Cat II is fine for around the house.
You don't even have to stand on them spare tires.
Man you got that right!Originally Posted by ballvalve
Whats terrifying is that they came WITH a battery and actually work.
Oh, how shocking! Thanks DonSounds like you were correct Bob.If there is no ground connection in the box then you would be measuring the device leakage.
It definitely is possible. Take a voltmeter and take an AC volt reading from the frame of the fridge to a ground connection (water pipe, or ground from another outlet that has a ground). If you can measure (hard for me to say how much voltage will give you a feelable shock) 24 volts or more, than you might feel a tingle if its just capacitance as I said above. If there is a real short circuit from the hot circuits in the fridge to its frame, then it will be dangerous. I guess your electrician must have checked this out for you in the name of safety?I may be misreading the posts, but although the outlet has been rewired, can the fridge still shock someone?
Thanks,
Bill
Can this happen? YesShouldn't the shell/handle be insulated from the current conducting components of the fridge (motor, wiring)? It seems a very dangerous design otherwise. The hinge on the freezer handle caused the original shock. Can this happen without a short in the fridge?
