Results 1 to 7 of 7
Thread: leak checking new bathtub drains
    DIY Junior Member pedixon's Avatar
    Jan 2012
    Wa.
    Default leak checking new bathtub drains
    Hi all. Am ready to leak check all my new drain lines, but not sure how to seal the bathtub over flow pipe for this leak test. Bathtub is already in place. I know I can get scew in plug for the tub drain itself.
    Jan 2012
    Wa.
    Just to clarify, this is new house. I am testing all drain lines.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    Jul 2009
    North Vancouver, BC
    You don't see the over flow tested other than just over filling the tub so that the tubs overflow is working.
    Have you already flooded out the stacks and vents prior to this?
    Often the tub's drain and overflow happen in a second inspection.
    I have never seen a tub's overflow "Plugged". Never.
    JW
    Jan 2012
    Wa.
    No, I have not already tested drains and vents. Didnt know you did that prior to tub being hooked up. So how could I do it now
    Homeowner
    Jan 2010
    Alabama
    I have tested waste and overflows along with the rest of the piping when the tub will not have an access panel or backs up to an outside wall.
    The thing is the manufacturer of your waste may not make a test kit for it. I'm not aware of a universal test kit so you may be stuck with disconnecting the waste and overflows and plugging the trap adapters
    Jan 2012
    Wa.
    Thanks for help. I have a watts so maybe I can get test kit.
  1. Checking E-Mail Without Opening it.
    By DonL in forum Computers and Stuff
    Last Post: 05-16-2011, 05:15 PM
  2. Newbie from Chicago checking in
    By 87vertgt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2009, 04:22 PM
  3. Checking Water Level - Sandpoint
    By mistermango in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-18-2009, 09:35 AM
  4. FWIW, Checking a 4-way switch
    By Thatguy in forum Electrical Forum discussion & Blog
    Last Post: 05-12-2009, 10:50 AM
  5. Checking Electric Water Heater Parts
    By white tiger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2006, 08:17 AM
