Results 1 to 15 of 15
Thread: I need a timer for a bathroom fan/light/heater combo.
    DIY Member Erico's Avatar
    Nov 2007
    NY
    Default I need a timer for a bathroom fan/light/heater combo.
    The plan is to place the heater on the timer and switch the fan and light.
    I have to check again, but I believe the heater is rated at 1000 watts.
    The largest wattage timer I have run across is 600 watts.
    Can anyone steer me to a supply house who carries higher watt timers? Perhaps my google fu isn't up to snuff.
    Here is what I have found and what I had in mind (only higher watt timer).
    http://www.iaqsource.com/product.php...product=172673
    http://www.leviton.com/OA_HTML/ibeCC...minisite=10022 has at least a few that are rated at 1800W. Depends on the style.
    Nov 2007
    NY
    Thanks for that.
    For some reason, I have the hardest time navigating their site.
    I still can't find the double rocker switch on their site. I know it exists becauuse it's on HD's website here:
    I sure would like to read the specs, Can find it under HD's published MFG model #.
    I assume a regular 15 amp double rocker would do the job of running the fan and light. Not sure what kind of wattage these switches are or what my fan uses.
    A fan is likely less than 200W, probably a lot less. As to the light, most won't hold more than about a 75W bulb.
    Jun 2009
    Canada
    You act like you're running a hair dryer on the timer...
    Nov 2007
    NY
    Huh?
    Jun 2009
    Canada
    Some hair dryers are 2000w, does everything you plan to hook up here seriously draw that much power?
    Homeowner
    Jan 2010
    Alabama
    Yes, he said a heater.
    Jun 2009
    Canada
    Quote Originally Posted by Hackney plumbing View Post
    Okay, my mistake.
    I was thinking heat-lamp and fan combo.
    You will probably need a rotary spring wound timer to handle that amperage.
    Jun 2007
    North Carolina
    Ever thought about a thermostat?
    The link I pointed him to provides several choices of timers that can handle 1500W and are electronic. Now, they are not a combo switch with a second/third switch for the light and fan, so he would need a multi-gang box. Sometimes, the fan manufacturer sells a combo switch deisgned for their product...since he did not indicate a brand for that, I didn't search for one, but he should. But, many places have their fan/light wired with two switches, so you could get a combo switch for those two functions, and put the heater timer in the other place in the box - or, just make the box bigger.
    Nov 2007
    NY
    I think you are correct. That's the way we will go. Also, I don't know if there is a nuetral in the switch box and some of those push-buttons require a nuetral.
    Nov 2007
    NY
    Quote Originally Posted by jwelectric View Post
    Not sure if I have seen one. I should have posted this for our summer/vacation home that we sometimes rent out. My fear is that someone will leave the heater on for a week.
    Nov 2007
    NY
    Yes, you did. And thank you.
    It's an old broan fan/light/heater original to the house circa 1971. It does have a proprietary control now.
    I need to add switches so I'm cutting a little drywall anyway and intalling a 3 or 4 gang box.
    I haven't pulled it apart yet so I'm not sure what those things went in to? Would it be a regular 2-gang box?
    At this point, I'm leaning to a mechanical winder timer because it appears some of thos push-button timers require a nuetral and I don't know if there is one in the switch box.
  1. bathroom light/fan combo
    By ElectricalNewb in forum Electrical Forum discussion & Blog
    Last Post: 08-14-2011, 05:18 PM
  2. Bathroom question, fan/light combo above the tub
    By TrevorO in forum Electrical Forum discussion & Blog
    Last Post: 09-19-2010, 10:00 AM
  3. bathroom heater/light power loss
    By Master Brian in forum Electrical Forum discussion & Blog
    Last Post: 05-26-2010, 03:42 PM
  4. Wire question on bathroom fan/light combo
    By gmaninca in forum Electrical Forum discussion & Blog
    Last Post: 05-17-2009, 01:20 PM
  5. bathroom light heater fan combo
    By Gfro in forum Remodel Forum & Blog
    Last Post: 05-16-2009, 09:19 AM
