wilbert
- Messages
- 14
- Reaction score
- 0
- Points
- 0
Local water treatment company recommends getting an acid neutralizer because our pH level is 5.9. They said if we get the neutralizer it will make our water harder so we will need a softener. Hardness is 4gpg now.
Hardness: 4 gpg
Iron: .5 ppm
pH: 5.9
TDS: 110 ppm
House has 5 toilets, 3 showers, little tub use, and 3 occupants.
They recommended a 13x54 Non Backwashing Acid Neutralizer w/ Vortech and a softener with the Clack WS1EE valve. I think the softener has Vortech also. The combo originally came with the following but he is upgrading me to the Clack for no charge. I don't know if that is good or bad and would just like some opinions on size and if I'm getting the right units for my application.
13x54 Polyglass Tank
Vortech Flow System, High Flow Rates, No Channeling Of The Media Bed.
Built In Media Platform No Gravel Bedding Needed
No Drain Line Or Electric Needed
Large Fillport For Easy Maintenance
Built In Bypass
1 Inch Threaded Pvc Connectors
2.5 Cubic Foot Capacity
Upper Distributor Basket Keeps Media From Escaping The Tank
Fleck 5600 Sxt Demand Softener (Clack WS1EE instead)
Removes Hardness And Iron
48,000 Grain Capacity
10x54 Polyglass Tank
Vortech Flow System, For A More Efficient Backwash And Higher Flow Rates
Fleck 5600 Sxt Electronic Deman Valve
System Monitors Water Usage, Andonly Regenerates When Neccessary, Conserving Water And Salt.
Large 18x36 Salt Tank
Bypass Included
Hardness: 4 gpg
Iron: .5 ppm
pH: 5.9
TDS: 110 ppm
Built In Bypass
Bypass Included
