Results 1 to 5 of 5
Thread: Replacing rotted drain under the floor with a pit.
    DIY Junior Member Mark DB's Avatar
    Jan 2012
    Dubuque, IA
    Default Replacing rotted drain under the floor with a pit.
    Hello,
    On one side of my basement I have the kitchen sink running down from the first floor going into the basement floor. The clothes washer drain ties into it and the only floor drain is right next to it. This is all 2" pipe and runs about 25 feet underneath the basement concrete, (and under the newer furnace), into a wye to the main then out of the house. The tubs and toilets all come down the stack about ten feet from the wye.
    I noticed about six months ago that the sump pump began running whenever the washer was used and when I finally made the connection I had the "hole" located. I cut up seven feet of floor and discovered that the two inch is cast and is completely rotted on the bottom. It appears to be rotted the entire length from the floor drain to the main and I would have to move my furnace to replace it all.
    I am seriously thinking about putting in a pit instead and am wondering how to do this, would it meet code, do I have to have a floor drain in the basement, etc. Any thoughts would be greatly appreciated.
    Thanks much,
    Mark DB
    Jan 2008
    What do you mean by a "pit"??
    Everything must drain to the building sewer main. Pipes can be relocated or re-routed, but they will need to connect to the building sewer, whether it be in the basement or in the yard.
    You could use a small pump designed for this - it doesn't need to be in a pit, then pump it to a place where it could drain. Gravity is better, though. As long as you can maintain the slope, the line doesn't have to run straight. There are limitations on how many turns a pipe can take, though. You'd want to find the other end and either cap it or run your new line into it. Something like this would probably work http://www.libertypumps.com/Products...?p=19&s=8&c=15. Check out their site to find the best one, if you want to go that route.
    Not running the washer into the pipe is only part of your problems. If the line is left under the floor, any time the sewer backed up that water would enter the sump pump, and what would you do about water on the basement floor if you do not have the floor drain usable?
    Jan 2012
    Dubuque, IA
    Default Thanks for the good feedback, need to think about this some more.
  1. Replacing Cast Iron Shower Drain / P-Trap & Replacing with ABS
    By n0teye in forum Shower & bathtub Forum & Blog
    Last Post: 08-29-2011, 02:36 PM
  2. My drain is rotted.
    By pmaru77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2011, 02:56 PM
  3. Replacing floor drain bowl in basement
    By carpnet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2008, 05:29 PM
  4. Replacing Sewer Drain Cap in Basement Floor
    By LFM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-06-2008, 06:42 PM
  5. Any plumbers advice on best way to replace a rotted toilet floor!
    By zimmee66 in forum Toilet Forum discussions
    Last Post: 06-04-2005, 07:23 AM
