Thread: Concrete in toilet drain
    DIY Junior Member JP420's Avatar
    Jan 2012
    Yukon
    Default Concrete in toilet drain
    Ok, so I have a toilet drain that has concrete in it. The washroom was retrofitted into an office and I guess they figured that was the best way to close up the drain, so now I need to figure a good way to get it out, any suggestions? The pipe that it's in will be old school cast iron and it's completely covered, the pipe goes straight down and the does a 90, but I can't see that because it's in concrete. Hoping not to have to jack hammer down to get at it.
    The normal way that is done, is to stuff it with newspaper to plug it, and then pour a concrete cap.
    You may be able to tap it out.
    Plumber jimbo's Avatar
    I once worked a job where the city was clamping down on house where owner converted to several apartments, without permits, and the bathrooms could never be made code-compliant ( in small closets, etc!!!). The city wanted concrete in the toilet drains, and they wanted a LOT of concrete!
  1. PVC drain through concrete slab
    By KSC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-17-2011, 08:11 AM
  2. New floor drain in concrete
    By albertalbert in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-19-2010, 11:26 AM
  3. Concrete in toilet drain pipe
    By dkehring in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-07-2008, 07:37 PM
  4. Help: Angled Toilet Drain Pipe in Concrete
    By jayk in forum Toilet Forum discussions
    Last Post: 03-12-2005, 05:10 AM
  5. Sower drain in concrete
    By keith in forum Shower & bathtub Forum & Blog
    Last Post: 01-21-2005, 02:17 PM
