Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: disposal backup in to other sink
    DIY Junior Member sspeed's Avatar
    Jan 2012
    Colorado
    Default disposal backup in to other sink
    When we bought this house nearly everything was wrong, down to the duct tape on electrical connections. While I've sorted most of it out, the disposal continues to elude me. When we turn it on it literally shoots water up in to the other sink.
    From a layperson's point of view it all looks right, it has a baffled T which appears to be in the right spot, the disposal drain tube is higher than the trap, the disposal tube is level (despite how my awesome camera angle looks)... what is going wrong? Here are 3 pics...
    I would pull the p-trap and make sure the drain below isn't plugged.
    If the drain is clear, then you shouldn't have water coming up the other drain.
    In the Trades Pipewrench's Avatar
    Mar 2011
    Jackson MS
    Does it do it when the disposal is completely clear with water flowing properly? If it has food in it and the bay is filling up then it tends to do it when you cut it on to clear it.
    Jan 2012
    Colorado
    It's usually when the disposal is not clear. I usually modulate the switch to get it moving and stop it from shooting out the other sink.
    Mar 2011
    Houston, TX
    Quote Originally Posted by sspeed View Post
    It is shooting out the other sink ?
    I find that very hard to believe.
    Please post videos. That must be cool.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    You have a partial stoppage and the waste pipe need to be augered.
    Snaked or rodded out.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Call a plumber or drain cleaning service co. To clear your kitchen sink drain into the main line and the water will stop coming back up into the sink !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Mar 2011
    Houston, TX
    True that.
    I still would like to see video of it "shooting out the other sink."
    Plumber jimbo's Avatar
    We can see in the photo that your Tee appears to be the "baffle" type, so only some clogging should cause that back up.
    Mar 2011
    Jackson MS
    Sounds like you are just moving a lot of water at one time with a good disposal. Looks like a badger 5. It wouldn't hurt any to install a new basket strainer too. You are missing the cross that is usually there. Doesn't sound like a blockage in the slab to me.
    Mar 2011
    Houston, TX
    If it is "shooting out the other sink." just put a plug in the other sink and clear the obstruction, by using plenty of HOT water.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Pipewrench View Post
    Is there any such thing as a good disposal.?
    They should not be allowed unless you have your own septic system, and have to deal with the problems that they cause to a sewer system. You would never own one, if you seen what is going down the drain.
    They are right up there with Tampons, On most reasons are taxes have to pay for Sewer Blockage. Trash in so Called "Storm Drain" comes next.
    Just me. I do apologize in advance. Go ahead and chew my ass out.
    DonL
    Jan 2012
    Colorado
    Sorry for the Vimeo, my phone was having trouble posting to YouTube... this will take about an hour to be available..
    This is the mild case that it does it, sometimes it's high enough to hit you in the face, usually when water is sitting in the sink... The line from the sink has been completely replaced and snaked several times before it was replaced...
    Mar 2011
    Jackson MS
    Of course there is such a thing as a good disposal. Like I said, a badger 5. It's like I tell customers, they are intended for washing off a plate. Not cleaning out the fridge. It kinda comes down to "common sense". It's gotta travel through a 1 1/2 pipe to hit the 2 inch....
    Mar 2011
    Houston, TX
    Yea, They also say that you can put bones in them.
    I am not sold.
    Most people do not care where it goes, Just as long as it gets Disapperated (Yes New Word). It must be FM.
  1. Double Basin Sink - Backup
    By jaspol in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2011, 07:56 AM
  2. Kitchen sink backup in a condo
    By songstj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-27-2010, 08:13 AM
  3. Sink backup
    By ckg1999 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2007, 07:09 AM
  4. Water Backup into Bathtub when using sink
    By johnnyportable in forum Shower & bathtub Forum & Blog
    Last Post: 02-28-2006, 01:56 PM
  5. garbage disposal causing minor backup in double sink
    By homey6660 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2005, 07:41 AM
