Results 1 to 4 of 4
Thread: Bathroom upgrade - shower mixing valve question -
    DIY Junior Member BlueBrummie's Avatar
    Jan 2012
    Methuen, MA
    Default Bathroom upgrade - shower mixing valve question -
    Hi folks,
    New to the forum and am looking for some advice/guidance about an upcoming bathroom renovation. I found a Moen shower faucet that I like but also found that the mixing valve has 3/4" inputs. I believe that this bath is serviced with 1/2" lines only (all dimensions ID). Current shower pressure is more than sufficient. Also, the new shower hardware is a shower head and handle combo, with each having a 2.5 GPM rating. So, my question is, will I be causing myself grief by putting a 1/2 to 3/4" adapter to interface to the new mixing valve? Also, I should say that I'm not likely to use both the shower head and separate handle at the same time, but I may.
    For completeness sake, let me add my home pressure is near 60 PSI at the main. and the distance from the main to the 2nd floor bath is approximately 25 ft of 1/2" feeding off a 30 ft of 3/4", slightly longer for the hot water line. The new shower hardware is the Moen TS270.
    If there's any other pertinent info you'd need to help, just let me know.
    Many thanks for your help,
    Erick
    The company often makes identical valve trim sets in both 1/2" and 3/4" rough-in versions; a 1/2" version will save you some money if it is available. No, it won't hurt performance using a reducer, and might even improve things a little as all valves have some internal flow resistance...a 3/4" one will usually have less than a 1/2" one.
    Jan 2012
    Methuen, MA
    Hi Jim,
    Thanks for the reply. After a bit of searching, I haven't been able to find a 1/2" version of the valve set (which is comprised of 1 temp valve and 2 volume valves for the main/handheld units). My inclination is to go ahead with my idea of adding the 1/2 to 3/4 transitions. If anyone else has thoughts/advice, I'd appreciate your input before I take the plunge and order the shower set.
    Thanks again,
    Erick
    Unless something has changed, all Moen valves use the same internal pieces so whether you use 1/2" or 3/4" would be immaterial.
  1. Bad Sterling Mixing Valve in Shower
    By Tleast in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2011, 07:14 PM
  2. shower temp mixing valve question
    By novasupra in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2011, 05:51 AM
  3. Replies: 3
    Last Post: 08-09-2010, 06:44 PM
  4. Need new shower/tub mixing valve
    By Scuba_Dave in forum Shower & bathtub Forum & Blog
    Last Post: 10-26-2009, 11:17 AM
  5. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
