Results 1 to 8 of 8
Thread: Pressing question on a Ford Van
Hybrid View
    Default Pressing question on a Ford Van
    Got a question for you good people with knowledge of vans.
    It is an E150 Ford 02, 6 cyclinder, with all gauges suddenly, not working.
    Possible causes?
    Thank you inadvance.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Cookie View Post
    Possible causes?
    It is a Ford ?.
    Fix Or Repair Daily, It is operating normally.
    LOL.
    Ground to dashboard controls, Blown F150 fuse.
    Actually, I agree with the Fix or repair daily, because I had a ford taurus which was so horrible. No matter what we did with the starter, replaced it several times, then a recall on it, used to be, I had to carry a rubber mallet and carry it, rap on it, if I shut the car off my " mistake." You left it running, at all times, lol. going thru the drive thru anywhere, bank, fast food, etc. I was glad we donated it... yes, we donated it.
    But, his van has been good until, now. I said, maybe a fuse, he said, no, not a fuse. You sure about this Don?
    I got a wager on it, lol.
    A vegetarian pizza. MY favorite...
    Mar 2011
    Houston, TX
    If it is not a fuse then I would check the ground going to Instrument cluster.
    Check the ground connection near the battery.
    It would almost have to be a ground problem, for it to be affecting all the gauges.
    He may want to verify 12Volts is making it to the Instrument cluster.
    Thank you Don. I checked with him, and he said, their's no fuse, so, it must be something else. Sometimes, I think, a Clysdale might be a good idea, like my friend in NZ wants for transportation, lol.
    Mar 2011
    Houston, TX
    There is a fuse, Everything is fused.
    I guess it just is not blown.
    The Ford F150 dash is known for bad solder connections. They may have the same problem on the E150.
    I own 2 Fords and they keep me busy.
  1. What kind of union fitting is this? Ford Fitting
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2011, 10:25 PM
  2. Quick question on glass framed pivoting shower door hardware question
    By watson524 in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2011, 05:38 PM
  3. Ford Transit Connect
    By Terry in forum Computers and Stuff
    Last Post: 07-25-2010, 12:36 PM
  4. Ford Products Aqua Coil
    By plumbernj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2006, 02:48 PM
