Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Help with slow leak
    DIY Member Kestrel's Avatar
    Aug 2011
    Seattle
    Default Help with slow leak
    I have a slow leak in some sweated copper.
    I'm replumbing part of my house - part of a new boiler install and hydronic system. I've started to test for leaks in my work, and on a complex part of the project, going from 1" -> 3/4" -> 1/2" with branches off each, totaling about 40' long, including the new water fill for the boiler, I've got a slow leak that I cannot find. I have a schrader valve with a pressure guage (up to 30 PSI) that I got at HD (I know - maybe that's the problem). Anyway, I pressurize up to 30, and I get a slow drift maybe about 1-2 PSI per hour. It drops over days to about 2-3 PSI and stops there. I've soaped every soldered joint, and a few PTFE-taped threaded joins in the boiler fill section, and I cannot find any bubbles forming. Is there another method for finding a leak? Do I need to use water, and look for drips? That seems like it might be more obvious. Help!
    I'd get a different gauge. Perhaps a higher quality one. My guess is, it is a gauge problem, and you have no leaks.
    Homeowner
    Jan 2010
    Alabama
    The air temp is probably changing. For example.....if your gauge reads 100psi and air temp at the time of the reading is 80 degrees.......if the air temp drops to 65 degrees the gauge would read less. if the air temp went up to 100 degrees the gauge would read more pressure. Simple as that.
    Quote Originally Posted by Hackney plumbing View Post
    Air temp won't account for it dropping to essentially zero...plus, with air temp, it would go both up and down with the temp, not consistently drop.
    Don't know if this could be an issue, but some circulators use water for the bearing lubricant, and when dry, might (not sure) slowly leak a little there.
    Homeowner
    Jan 2010
    Alabama
    No it shouldn't continue to drop to zero. I'd fill it with water and check for drips.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Most likely around the gauge. Check very carefully around the entire gauge setup/schrader valve, etc.
    Jan 2008
    More often than not, any leaks will be at threaded fittings- including those on your test equipment.
    Jun 2009
    Canada
    Let me get this straight.
    All of you came up with the suggestion to look at the gauge for leaks, instead of the rest of the house?
    Are you serious. Do you think he didn't make sure the gauge had a tight connection?
    Jan 2008
    It could be in a bleed valve, the fill valve, or the threaded fittings on the test equipment.
    Could it be a bad solder joint? Sure. Filling it with water might or might not help.
    I'm sorry if you felt left out Dan. Don't worry, I still love you too.
    Jun 2009
    Canada
    You must since I never mentioned my first name on this forum...
    Are you stalking me?
    If you have 30 PSI of air in the pipes, you would hear a leak.
    Aug 2011
    Seattle
    Terry - that's helpful, and in fact, when I first set it up, I did indeed find a soldered joint - one in an awkward position that I knew I was not as graceful making in the first place. It was audible and sputtering at 20-25 PSI. I took it apart, cleaned it up and resoldered, and its quiet now, and no bubble with soap either.
    When that one was leaking, I would pressurize up to 25 or so and I could watch the needle drop to 0 in a minute or two - really fast.
    Now that that is fixed, I pressurize up to 25 or 30, and the needle drops really slowly - it'll drop down to the teens overnight, and down to 2-3 in a day or two, and stop there. I hear no hissing anywhere, and like I say, I've soaked all the joints with soapy water and cannot find a source of bubbling.
    There are two threaded joints - at either side of a Y-strainer at the boiler fill portion - but no bubbles. I was thinking already of taking this apart, re-taping and putting it back together.
    The circulators in the boiler circuit are not seeing the pressure yet - I have the ball valves to the boiler from the cold water closed, and to the hop water pipes as well - I was trying to test in segments.
    I'm going to take the test gauge down, re-tape it and see what happens. If that doesn't fix it, I'll take down the taped joints at the Y-strainer. And if that doesn't fix the loss of pressure, then I'm thinking that I'll charge the line with water and look for drips.
    Go to a toy store and get some kid's bubble solution. Spray that on all the joints. If you have a slow leak, it will "cling" to the joint a lot longer and create bubbles if there is a leak. Plus, the bubbles will remain at the leak a lot longer than soap will.
    Aug 2011
    Seattle
    Oh - good idea - that stuff has glycerin in it, and is more tenacious - and I know we have some - I'll try it. thanks
    Feb 2011
    NW Ontario, Canada
    Maybe the valves are leaking internally.
  1. Slow leak beneath toilet
    By lumsden in forum Plumbing Forum Discussion & Blog
    Last Post: 01-16-2008, 08:34 AM
  2. tub caulking won't dry. Slow leak behind wall?
    By cygnus in forum Shower & bathtub Forum & Blog
    Last Post: 07-19-2007, 03:13 PM
  3. Very Slow Leak at Shower Valve
    By HR in forum Plumbing Forum Discussion & Blog
    Last Post: 02-10-2007, 04:17 PM
  4. Slow leak in bathroom
    By kramer12345 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-29-2006, 01:17 PM
  5. Can anything stop a slow leak without disassembly?
    By chiguy in forum Plumbing Forum Discussion & Blog
    Last Post: 06-22-2006, 07:51 AM
