Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Install Electric WH in series with existing tankless
  1. #16
    DIY Junior Member rootuser's Avatar
    Jan 2012
    Silicon Valley, California
    I suppose it's a good start until I get a new tankless that can handle more volume. If I'm good for a 10-15 minute burst at full hot that will be enough in most situations right now. At some point I'll look at running them a little different to better address the volume problem. At this point I'm doing one thing at a time, and fixing the short-cycle problem would be a win right now.
    Anyone have a suggestion on a decent 10-20 gallon electric tank waterheater? Do you know what kind of circuit I will need to run? Is a 20-amp dedicated enough or should I run a 30? I can do either as this will be a new circuit I'm installing just for the water heater.
  2. #17
    Run a 30A, 240vac circuit, then, you can install almost any residential electric WH. On a 20A branch, you limit your choices. The wire will cost you more, but the flexibility is worth it.
  1. Combining an electric Tank with electric Tankless
    By Dkrasko in forum Tankless Water Heater Forum
    Last Post: 03-27-2014, 08:24 AM
  2. Rheem Tankless H95 Direct Vent Indoor Series water heater
    By Terry in forum Tankless Water Heater Forum
    Last Post: 04-22-2011, 04:18 AM
  3. Tankless to supplement existing conventional w.h.
    By BusaNoob in forum Tankless Water Heater Forum
    Last Post: 02-09-2011, 03:09 PM
  4. Electric Tankless Help!
    By schinks in forum Tankless Water Heater Forum
    Last Post: 06-27-2010, 07:38 AM
  5. Combining an electric Tank with electric Tankless
    By Dkrasko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2008, 03:14 PM
