Results 1 to 6 of 6
Thread: Low Hot water amount since main valve replacement. Volume seems fine
    DIY Junior Member RobPin's Avatar
    Jan 2012
    Mississauga, Ontario, Canada
    Default Low Hot water amount since main valve replacement. Volume seems fine
    Hi I recently replaced the main shut off valve coming into the house. Since then I'm running out of hot water. This was never a problem before. The volume of water seems OK pressure wise but the amount of Hot water seems decreased and ends in half the time now.
    Any thoughts
    RobP
    Feb 2011
    NW Ontario, Canada
    If you have an electric water heater and did not turn off the breaker when the work was done, there is a distinct possibility that an element burned out. If you have a gas heater and it was turned off, it may have simply reverted to the default temperature and may need to be raised.
    Jan 2012
    Gas heater. Only shutoff cold water valve going into tank during draining of line, but turned it on afterwards. Thanks for reply
    I would check the temperature setting on the gas heater.
    Jan 2012
    Will increase. Could solder have traveled down the pipe and be stopped at the cold inlet (theory).
    Rob
    Feb 2011
    NW Ontario, Canada
    Many water heaters have heat traps in the nipples of the inlet and outlet. Sediment can prevent smooth movement of the ball of the heat trap that could in turn severely restrict the flow but those are not the symptoms you describe.
  1. Main water valve replacement
    By darmstro in forum Plumbing Forum Discussion & Blog
    Last Post: 04-01-2011, 01:38 PM
  2. Material for replacement buried main water line from the curb?
    By greendog in forum Plumbing Forum Discussion & Blog
    Last Post: 02-18-2011, 11:41 AM
  3. Under ground water main - replacement
    By jdf405 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-08-2009, 09:15 AM
  4. Why is sink shutoff valve still leaking after main water valve turned off?
    By kimana517 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-18-2008, 06:28 PM
  5. Computer-controlled digging for water main replacement?
    By Liv in forum Plumbing Forum Discussion & Blog
    Last Post: 08-03-2007, 07:57 PM
