Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: Dare I put a wood window in a shower wet wall
  1. #16
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    lap joint - hmm, thinking like a carpenter ;-)
    In this, would you lay the stone on the sill, see where the tile would butt up (pencil) and then grind a reveal under the stone sill....
    To make the back of the stone look nice where it meets the window it needs to be back cut as well a few degrees.
    A picture describes a million words. Got any ?
    Are you saying put a reveal into the frame --- if the material allows, to slide and *lock* the stone ontop as well...
  2. #17
    Jul 2009
    North Vancouver, BC
    post(s) deleted by John Whipple
  3. #18
    Jun 2006
    Back to homework. While not familiar with the Noble/Schul Sealants---for the window.......I'm inclined to look at tried and true performers. I have to see what the equivalent of a interior grade application would be comparative to NP1/NP1, Vulkem 116, Solar Seal. I've used all these with great sucess....and I suppose interior is fine as long as I'm okay with the dissipation aroma.
  4. #19
    Jul 2009
    North Vancouver, BC
  5. #20
    Jun 2006
    All those exterior grade stuff is good stuff. They just stink as they outgas.
    My plan is all liquid but I was planning to use membrane on area like the window and niche.
    I suppose one should stick with their manuf. recommended sealant when not know how the chemical composition of the latter *tried and true proven* sealants would behave with their membrane material....from a systems approach..
  6. #21
    Jun 2006
    Thread Bump. Project back on track for this year.
    JW,. Let me see your *flashing* / expansion gap treatment between tub edge and mating wall...
    I'd be curious what techniques to employ
  7. #22
    Jul 2009
    North Vancouver, BC
  8. #23
    Jun 2006
    Thanks JW. Pics speak a milliion words. Your pics were *more or less* what I have in mind, re: sheet membrane as the flashing.
    I'm going to *google kerdi fix* cause I can think of 10 zillion other great urethane sealants I can buy and use that are proven performers for me.
    VOC....aside.
  9. #24
    Jul 2009
    North Vancouver, BC
  10. #25
    Jun 2006
    Is that a triple deck staggered niche u built there ?
    Most urethanes skin over quickly. Kerdi Fix is not a easy find at the supply houses around here, and if I was to get my hands on it, I would be very suspect on it's production date. Tons of good/great Urethanes like Vulkem, Sonneeborn, SS, etc. I've used them when sealing perimeter holes, if not sealing on the inside, the sides of a window during rough framing. Kerdi Fix is just hard to get, probably will be outdated on the stuff if I do get it, and well, as you know, in the tile world if not anything using construction materials, it's good practice to check batch code dates
  11. #26
    Jul 2009
    North Vancouver, BC
  1. Wall Window A/C Condensation Doesn't Drain
    By nin28 in forum HVAC Heating & Cooling
    Last Post: 07-18-2011, 11:16 AM
  2. 1970's Wood Strips on Wall
    By bisjoe in forum Remodel Forum & Blog
    Last Post: 09-06-2010, 09:09 PM
  3. Replies: 11
    Last Post: 09-03-2010, 08:52 AM
  4. window in shower waterproofing
    By daddio in forum Remodel Forum & Blog
    Last Post: 09-08-2009, 08:16 PM
  5. Leaky Window in Shower - HELP!
    By cetteis in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2009, 07:11 AM
