Results 1 to 9 of 9
Thread: Recommended shower install materials??
    DIY Senior Member jch's Avatar
    Jan 2006
    Victoria, British Columbia, Canada
    Question Recommended shower install materials??
    I'm in western Canada (Victoria), so I'm looking for advice about products available here.
    Been reading the posts about Kerdi here and on John Bridge and I'm getting overwhelmed.... Been to Big Orange and some contractor tile places and the number of choices is staggering!
    For a first-timer like me, specifically what brands would you recommend I use for materials in a simple tiled shower (no niches, but with tiled sloped ceiling, rafters 24" OC)?
    i.e. which brands of:
    • Wallboard,
    • fasteners,
    • tape
    • tape mud,
    • waterproofing,
    • tile-setting thinset (for 12"x4" tiles, plus 1"x2" glass mosaic strip), and
    • grout
    Appreciate any *specific* help you could share. Once I've got specific recommendations, I'll go look up the specific installation instructions on the manufacturers' sites.
    - John
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    John -
    It's not the brands but the process...
    Non Shower area - sheetrock treatment is fine.
    Shower - Wet Wall Area - any concrete board of choice , denshield, hardiback
    Some caulk between the joints of CBU.
    I've always just used a alkai resistent tape and thinset
    Don't use drywall mud for the shower area.
    Waterproofing - Look at both liquid and sheet membranes. FWIW, I'm doing my next project with liquid and certain area like the niche, I plan to use sheet and liquid. Maybe overkill but I tend to build solid like a rock. (Carpenter was cursing up a storm when I had him change the RO for a interior door recently that I built out years ago) ......
    Grout and thinset is subjective but Laticrete and Mapei are fine brands I prefer.
    KEY advice. ALWAYS check the date /batch codeof your product. Make sure it's fresh IMO.
    Grout- you ideally want them of the same batch code
    Grout - Epoxy all the way for me. Cost more (labors just the same to me IMHO). Most epoxy grouts have a less than 1% absorption rate.
    If you plan on white, you may NOT want epoxy just due to color
    YMMV. Good luck
    I prefer a surface membrane, whether a sheet or liquid...it just leaves much less that can get wet in a shower. Whatever you choose, you must use good workmanship. A conventional liner shower will work, too, but surface waterproofing has its advantages. 24" OC ceiling may be a problem...some stuff can handle it, some can't, so read the instructions carefully. You could using strapping and possibly some intermediate supports to narrow that 24" OC if required, but it might lower the ceiling, leaving a step, depending on method used. one person's experience/predjudice should not make your definitive decision for you...lots of people have used and created successful showers with each of the available methods out there...some are easier for the first timer and I have my preferences, but that's one person's opinion, too.
    Jan 2006
    So how about if I use 2x6 blocking (with the 6" face against the ceiling) to span those 24" rafters?
    Big Orange only carries a limited number of products, and pro tile shops seem to carry a dizzying array of products.
    That's why I'm asking for specific recommendations for a newbie like myself.
    - John
    Jul 2009
    North Vancouver, BC
    post(s) deleted by John Whipple
    Jan 2006
    Sorry--should have mentioned that this will be a cast iron built-in tub (Kohler Villager) with shower head...
    If I go to a pro tiling store instead (which is often cheaper than Big Orange), would that change your recommendations? I'm in BC.
    - John
    Jul 2009
    North Vancouver, BC
    Plumbing Contractor Will Rogers Plumbing's Avatar
    Oct 2010
    Moore, Ok
    Wallboard, Permabase
    fasteners, Roofing Nails
    tape Fiberglass or stucco mesh
    tape mud, Thinset
    waterproofing, Kerdi with Kerdi Drain or Aquadefense with divot method
    grout Customs Versabond for thinset, SpectraLock or Truclolor for grout
    Moore, Oklahoma
    http://www.willrogersplumbing.com/
    Oct 2010
    Moore, Ok
    Quote Originally Posted by jch View Post
    If your just doing a tub surround then permabase walls, thinset and tape your joints and corners with fiberglass mesh tape. Water proof with Aquadefense on the corners and seems. You don't have to go all crazy with the water proofing on a tub surround. I like spectralock expoxy grout, trucolor urethane grout is good too, but less forgiving.
    Moore, Oklahoma
  1. Building a Shower Pan - Recommended Mortar Mix?
    By danelectro in forum Shower & bathtub Forum & Blog
    Last Post: 08-24-2011, 09:20 PM
  2. shower -- silicone or caulk recommended?
    By b kempkes in forum Shower & bathtub Forum & Blog
    Last Post: 06-28-2010, 12:54 PM
  3. Recommended Shower Drain for Sterling Ensemble Shower?
    By thebigsee in forum Shower & bathtub Forum & Blog
    Last Post: 09-28-2009, 03:30 PM
  4. Looking for new shower pan, need advice on materials, please
    By KathyH in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2006, 06:47 AM
  5. Custom Shower Materials
    By SouthTexan in forum Shower & bathtub Forum & Blog
    Last Post: 07-22-2006, 05:25 PM
