Results 1 to 5 of 5
Thread: A "Typical configuration" for a Shallow jet well?
    DIY Junior Member D1Case's Avatar
    Jan 2012
    Chesapeake, VA
    Default A "Typical configuration" for a Shallow jet well?
    After a couple years of neglect, I am trying to refurb a shallow well that feeds my irrigation system. It's a 2" jet well, 45 feet deep, with the water column rising to 9 feet deep. I am fairly sure there is a sand point on the end.
    Removing the seal, I was surprised to find the 1" suction tube to be about 6 feet shorter (39 feet).
    I was also surprised that instead of having a foot valve, the suction side went down to an injector/venturi fitting(?), slightly bulbous area for a lower seal, then ended with a check valve.
    While this design seems to work, I was left wondering if there might have been something in that gaped 6 feet, or is this a "typical" configuration? And if it is typical, what would the normal range for the check valve's height above the base?
    Feb 2011
    NW Ontario, Canada
    That is a very normal packer deep well setup. How low to set it depends on how low the water table may get and how much sediment may build up in the bottom of the casing.
    Jan 2012
    Chesapeake, VA
    Thanks.
    Seeing the open ended check valve had me overthinking it.
    Feb 2011
    NW Ontario, Canada
    I don't know what you mean by open ended. First off, what you describe is not a shallow jet well. A shallow well jet pump uses only a single pipe. A deep well conversion uses two pipes, one for suction and the other for pressure.
    Nov 2010
    Maine
    The water pump pushes a volume of water down one line, through a venturi which in turn sucks water up to feed the suction side of the pump. The foot valve keeps the system primed.
  1. Replies: 4
    Last Post: 03-09-2010, 07:52 AM
  2. "Traditional" BW, or "Condensing" BW, or "Condensing" American?
    By rickst29 in forum Water Heater Forum, Tanks
    Last Post: 10-27-2009, 07:39 PM
  3. "Machine Gun" or "Thud" and a Weeping Toilet...oh my!
    By maxxis in forum Plumbing Forum Discussion & Blog
    Last Post: 03-22-2009, 07:38 PM
  4. Difference between "thinset" and "dryset" mortar...?
    By Fistor in forum Remodel Forum & Blog
    Last Post: 07-31-2008, 02:44 PM
  5. Say "no" to the AS Champion toilet & "yes" to Toto
    By badeb in forum Toilet Forum discussions
    Last Post: 04-18-2006, 09:32 AM
