Results 1 to 4 of 4
Thread: Fleck 7000 cam not depressing Brine Valve Assy?
    DIY Junior Member sts7's Avatar
    Jan 2012
    Maryland
    Default Fleck 7000 cam not depressing Brine Valve Assy?
    I recently had my water softener serviced because the Fleck 7000 control unit wasn't keeping track of the gallons of water that were being passed (the display was stuck at 3200 or so). The service technician found that the brine tank was nearly overflowing with water, and determined that the Brine Valve Assembly on the Fleck 7000 needed to be replaced. (And he replaced it.) The system had been filling the brine tank with water, but not sucking it back out into the softener.
    A couple of months have gone by and I noticed that the water isn't getting softened anymore. The Fleck 7000 is tracking the number of gallons used, so the problem isn't the same. I can also force a regeneration, but it didn't seem to soften the water.
    I forced a regeneration and watched what happened. It looks like the cam doesn't depress the brine valve sufficiently to send water to the brine tank. I pushed the brine valve a bit further by inserting a screwdriver between the cam and the valve, and it began to fill the brine tank. It looks like the cam isn't depressing the valve far enough to open it.
    Is there any sort of adjustment that I can make to fix the problem? Is there any sort of adjustment that needs to be made when installing/replacing a brine valve? I'd like to find an easy solution to the problem, but I can't figure one out.
    Any help would be appreciated!
    Victor
    Dec 2009
    Alaska
    Sounds like the wrong brine piston was used on the 7000, most likely the 5600 was used when the one for the 7000 should have been used.
    The two are close but the one for the 7000 is a bit longer than the 5600 or 9000 brine valve.
    Simple fix, but they should come out and replace it and make it right.
    Jan 2012
    California
    Agreed, the 7000 brine valve is just slightly longer. We see this a lot especially since the 7000 is a little over 10 years old, it is finally starting to need to be serviced in the feild and a lot of technicians are not aware that the brine valve is different. A very easy and common mistake.
    Jan 2012
    Maryland
    Thank you very much for your replies. Very helpful.
  1. Programming Fleck 7000 SXT
    By WolfB in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-23-2011, 04:53 AM
  2. Connecting a 1-1/4" fleck 7000 bypass valve to water supply
    By geod in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-01-2011, 10:34 AM
  3. Fleck 7000 Problem
    By ArayT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-03-2011, 11:04 PM
  4. Help Programming a Fleck 7000 SXT
    By batboy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-03-2010, 06:43 PM
  5. fleck 7000 or clack ?? help
    By gerrythegreat in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-24-2006, 08:30 PM
