Results 1 to 4 of 4
Thread: Double Sink double dishwasher garbage disposal dilemma
    DIY Junior Member Pettytalk's Avatar
    Jan 2012
    California
    Default Double Sink double dishwasher garbage disposal dilemma
    Hi
    I was wondering if someone can help me. I had this configuration installed 2 years ago and since Ive had to snake the main line (in my back yard) at least every 6 months. Im tired aof renting a snake, shouldnt my garbage disposal be on the left side? My drain is on the right side and I noticed with 2 of my family members that on their set up (the same as mine) they have the disposal on the left hand side ( dishwasher on the left hand side as well. I notice that the water backs up a lot on the right side (non disposal side) until I turn on the disposal. Then the water goes down. Should I switch disposal with the non disposal side? Anything you can help would be apprecaited. Im tired of getting blisters from feeding the 50' auger in my backyard drain.
    Part time plumber in California
    ~$Doc2.doc
    It should make no difference what side the disposal is on, especially out in the main. If there were any ill effects to how the disposer was mounted, that is just in how the sinks work. Something else must be going on.
    Is it an older disposer with worn out chambers? Are folks sending down a lot of rice or potato peelings????
    If your disposer is eight years or older, then you might consider replacing it.
    If you are snaking every six months, you also might consider replacing your disposer. An old worn out disposer doesn't chip up the food into small enough bits that will float down a drain.
    Left or right makes no difference.
    If your main line is getting plugged every few months it is not the disposer causing it. The condition of the disposer is what would cause drain problems, not which side it is installed on. Your link brings up gibberish, so I am not sure how the disposer is connected, but that would also be more important than the side it is in. We install the disposer on the side that makes it easiest to connect to the drain.
  1. Replies: 5
    Last Post: 12-07-2011, 01:38 PM
  2. double sink shooting water up thru drain when garbage disposal is on
    By gwheels16 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-13-2011, 09:13 PM
  3. install garbage disposal in double sink
    By homey6660 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-06-2009, 07:35 AM
  4. Double sink garbage disposal, which side?
    By GARMAN in forum Remodel Forum & Blog
    Last Post: 04-17-2008, 12:15 PM
  5. garbage disposal causing minor backup in double sink
    Last Post: 03-31-2005, 07:41 AM
