Results 1 to 2 of 2
Thread: "play" in copper pipe
    DIY Junior Member rmc115's Avatar
    Dec 2011
    Default "play" in copper pipe
    I have a 40+ year old slab home with copper piping that runs horizontally in a sort of "manifold" between the bathroom and kitchen double walled void. I have been doing some remodeling work in the bathroom, which resulted in accidentally bumping the nipple/valve for the toilet supply. Not very hard, but enough to notice that this pipe has about 1/8 - 3/16" of play.
    I'm known to freak out over the smallest things, and with my limited knowledge of plumbing systems, did I compromise the integrity of the copper? The pipe is strapped in the wall with copper clamps every two studs or so. Nothing was bent or changed in any way, just a soft bump with my foot. I'm hoping someone can help me rest my anxiety-driven mind.
    Thanks for your help!
    Normally this isn't a problem. The only issue you may have is if it moved a lot on its own over the years and wore a hole in the pipe against something harder like a nail or a screw or a clamp.
  1. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
    By dayster in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2011, 04:51 PM
  2. pipe hangers 1" copper
    By gilmil in forum Plumbing Forum Discussion & Blog
    Last Post: 12-14-2010, 10:44 AM
  3. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum Discussion & Blog
    Last Post: 11-01-2010, 11:57 PM
  4. "Notching" studs vs. holes in studs for copper pipe?
    By ironspider in forum Plumbing Forum Discussion & Blog
    Last Post: 01-19-2010, 04:54 PM
  5. How to solder a "T" in copper pipe?
    By rsmith99 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-14-2008, 05:29 AM
