Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Overhead garage door repair - frustration
  1. #16
    Yakima WA
    I revisited this thread not realizing it was an old one that had been revived. As I read the various answers, I began formulating a reply until low and behold, there was my reply...the one I had made when the thread was new. Reading on, I again starting thinking about a response, when again I came upon my own reply. My suggestions haven't change. Don't screw around with garage door springs. It is not unmanly to admit there are somethings you can not DIY safely and/or properly and are best left to the pros. Sure, you can pull the release cord and open the door manually so you can get the car out, but that's far enough.
  2. #17
    quote; I want to get a good diagnosis on it, so when I call the repairman I can point to what needs fixed so he doesn't spent more time than needed searching for the problem.
    IF he is a "good" door repair mechanic, he DOESN'T need you to tell him how to fix it. AND, there may be a completely different problem than you think you have, regardless of YOUR diagnosis. Tell him what is happening and let him do the diagnosis. IF you tell him what you want done and he does ONLY that, you are going to be unhappy if the problem happens again in a short time and might say it is his fault for not fixing the REAL problem. In my business, I seldom, if ever, listen to what the customer says is the SOLUTION/repair and just ask him/her what the PROBLEM is. Then I find the source of the problem and fix it.
  3. #18
    Mar 2011
    Houston, TX
    Very True.
    That is Great.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
  4. #19
    Yakima WA
    I wonder if the OP does the same thing when he has a medical problem, or if his car isn't running right? Sadly, lots of folks think they are doing the professional repairman a favor and can save some money if they diagnose the problem. HJ's response is right on the money.
  5. #20
    Mar 2011
    Houston, TX
    Default It is nice to have a good helper
    The funny thing about it is the first thing the doctor asks is "what is wrong with you".
    I say if I knew I would not be here.
    Doctors are always practicing.
    HJ is right on the money, and has a great helper.
    Name:  Love Helper.jpg
    I bet HJ plays Doctor a lot.
  1. Garage Door Opening Wall 2x4 or 2x6?
    By Lakee911 in forum Remodel Forum & Blog
    Last Post: 08-11-2009, 01:50 PM
  2. Garage door in RO less than door width?
    By jrfiero in forum Remodel Forum & Blog
    Last Post: 06-19-2009, 05:36 PM
  3. Garage door opener
    By shluffer in forum Electrical Forum discussion & Blog
    Last Post: 01-12-2009, 05:29 PM
  4. framing garage door
    By teamo in forum Remodel Forum & Blog
    Last Post: 09-12-2008, 01:52 PM
  5. New Garage Door Installation
    By Mike50 in forum Remodel Forum & Blog
    Last Post: 06-14-2008, 01:29 PM
