Thread: Water Bubbling from ground outside pump house
    DIY Junior Member 5berryfarm's Avatar
    Jan 2012
    Oregon
    Default Water Bubbling from ground outside pump house
    I just noticed that our pressure tank was running constantly. Then I found two small holes in the soil outside the pump house where water was bubbling up and now the ground in that area is saturated. Both holes are located on the same side of the pump house. I just shut the water off...and the bubbling stopped immediately. We still had good pressure and water to the house....until I shut it off. What could the problem be?
    Feb 2011
    NW Ontario, Canada
    You have a hole in the pipe.
    Jan 2012
    Oregon
    Thank you for the reply. I got impatient waiting for my husband to get home so I started digging. Luckily I found the issue (I think) fairly quick. It is a joint that is about 2 feet from the well house. I shop vac'd out the hole and then returned the water to light pressure...the joint started spurting and spraying water. There is a LARGE hole/void in the ground just underneath the joint. Does the joint need to be replaced all together or ??? There does not appear to be any cracks or breaks in the pipe. It seems as if the joint slipped....like the sleeve was too short?? Here is a photo http://i883.photobucket.com/albums/a.../Pipe/Pipe.jpg
    DIY Junior Member greenmonster304's Avatar
    Apr 2011
    Hampton Bays, NY
    You need to cut out the old coupling and replace with a short piece of pipe and one of the following knock on coupling, compression coupling, 4 90's, or slip fix.
  1. New House using Lake water - what type of pump do I need?
    By Lakegirl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-20-2011, 09:48 AM
  2. Should we use 75 or 100 psi pipe to pump our lake water to the house?
    By mblond in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-10-2011, 07:17 AM
  3. Above Ground bladder style pump won't turn off and no water pressure
    By kimmie2000 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-02-2010, 04:40 PM
  4. Water Pressure Booter Pump w/softener and whole house filter
    By dsteph3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2010, 06:12 AM
  5. Bubbling Water Heater
    By Puzzled Homeowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-12-2007, 08:56 AM
