Thread: Which fitting to connect two horizontal vents into one vertical?
    DIY Junior Member pbfj84's Avatar
    Jan 2012
    St. Louis, MO
    Default Which fitting to connect two horizontal vents into one vertical?
    I have 3" and a 1 1/2" horizontal vents that i want to tie together and go vertical out the roof.
    This connection will be made in the ceiling before going out the roof.
    I thought about using a combo wye/tee or sanitee fitting but those fittings would only slope back to the vent in one direction. Doesn't it need to slope back to both vents?
    A two way clean out fitting is the only thing I know of that would accomplish that.
    Since the connection is above the flood plane of the fixtures below, you can use a santee.
    ABS, and PVC, fittings do NOT have a "fixed slope" to them. Once you apply the cement you can "bend" them as necessary to get the slope. I do not know how you intend to make the connection or how a "two way cleanout would work because you would have to use bushing to reduce to the branch sizes. Almost any conventional fitting will work, but you may be thinking of a "vent tee" which is "square" without any "sweep" in either direction.
  1. Any disadvantages to horizontal repipe now and vertical later?
    By pinkoos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2011, 11:45 AM
  2. how to connect cast iron to pvc in a vertical run
    By bbsux in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-06-2008, 08:31 PM
  3. Moving Water Meter from Horizontal to Vertical Position
    By jluksic in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-12-2008, 09:44 PM
  4. Horizontal vs Vertical HWH
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2006, 06:31 AM
  5. Going vertical from a horizontal waste line
    By MajMetro in forum Remodel Forum & Blog
    Last Post: 04-26-2005, 08:57 AM
