Thread: Double sink / Disposal / Dishwasher - old home renovation advice needed
    DIY Junior Member k.k.'s Avatar
    Oct 2009
    Philadelphia PA
    Default Double sink / Disposal / Dishwasher - old home renovation advice needed
    Hi -
    I'm getting ready to do the plumbing for my kitchen remodel and had a question regarding the drain line for a Double sink / Disposal / Dishwasher
    Currently drain goes through the floor in the basement where it is tied into 4" cast that goes into the masonry foundation. No Vent
    I was going to do an S-trap but after reading other posts on this site, it seems that is not the way to go. Does anyone have any recommendations for what I can do without adding a vent line that would extend through the roof? My first guess was that I could design it with a P-Trap according to the diagram that Terry has posted in other discussions... Then instead of a vent line above the p-trap, i would have an Air Admittance Valve. Would that be an appropriate solution?
    Ken
    As long as you have the plumbing system vented through the roof, then you could use an AAV on the kitchen sink.
    Oct 2009
    Philadelphia PA
    thanks. Unfortunately I don't think this portion is vented through the roof. From what is could see, it was tied into the drainage system for the downspouts The downspout drain on the one side of the house seems to enter the basement and then is taken across the basement to the foundation wall on the other side - Where the kitchen drain is then tied into it. So confused - this situation is isolated to the kitchen. The bathroom has it's own section on the far end of the basement 20 ft away, where it enters the foundation (vented system)
    Your description is confusing enough that we cannot tell if an AAV would be appropriate or not.
  1. Garbage disposal install in double sink w/dishwasher... why do I have two drain pipes
    By s_mack in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2011, 01:38 PM
  2. install garbage disposal in double sink
    By homey6660 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2009, 07:35 AM
  3. Double sink garbage disposal, which side?
    By GARMAN in forum Remodel Forum & Blog
    Last Post: 04-17-2008, 12:15 PM
  4. Proper plumbing for double sink w/ disposal
    By bbach in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2007, 05:18 PM
  5. garbage disposal causing minor backup in double sink
    Last Post: 03-31-2005, 07:41 AM
